| rs182 |
Oct 6 2011, 11:02 PM
Newbie ![]() Group: Members Posts: 11 Joined: 18-September 11 From: Las Cruces nm Member No.: 13,569 Region Association: Southwest Region |
I am parting out my slant nose 914 but ran across this 72 on CL went to see it. Motor runs but the owner is not sure what size it is. He bought it for a project and never got time. Some body just bolted a carb on to what looks like the stock FI manifold. The injectors are still there (just not hooked up obviously) There is no serial number on the top of the motor and the dip stick is on the front like a type 1.
What do you guys think? He thinks its a 1.8 but the dip stick is throwing me off. Could it be a type 1 with type 4 cooling system?? I am new to 914s and my current 1.8 and some internet scouring is all the info I have on these motors Car is kinda ruff (crappy color change and a few dents) interior is pretty stripped but only minor rust on the passenger side jack area clean hell hole. He wants 1200 with a tail shift that jumps out of gear thanks Jason |
| rs182 |
Oct 6 2011, 11:23 PM
It might be to your advantage to show us some pictures. That we can viciously pick it apart for no apparent reason other than sheer perversity. BTW, the dipstick location could be for either a bus or a T4. '72 busses had the SN on the shroud. The Cap'n I know I should have taken pics. I had decided not to by the car (he wanted 1500) He called me back and said 1200 takes it. Good to know about the dip stick location on type 4 and buses. I thought they were all on the top If there is no serial number to see, then it is probably either sanded off, or it is a true spare Type IV case with no number. Did not know they existed til today when Bruce Stone came to visit and told me he has a numberless replacement case. Or it was burned off. There are ways to tell what the case is, and part of it is, are the plugs truly vertical or do they go into the block on an angle? Straight down is 1.7 or 1.8. 2.0L is at a 45 degree angle or thereabouts. Very easy to see. John I am going back on sat. to look at it again. Ill keep the plug angle in mind. Im taking my compression tester as well so Ill get a good look. Sounds like it may not be a 914 motor huh maybe a van. Does it really matter power wise? Its getting the dual webers of my current 1.8 wither way (as long as its a type 4 motor and not a type 3 or something crazy) There is no thermostat control rod or thermostat for that matter either.......made me kinda nervous |
rs182 mystery motor Oct 6 2011, 11:02 PM
kg6dxn Could be a T1 engine with T3 tin?
:ttiwwp: Oct 6 2011, 11:11 PM
rs182
:ttiwwp:
I n... Oct 6 2011, 11:15 PM
Cap'n Krusty It might be to your advantage to show us some pict... Oct 6 2011, 11:13 PM
avidfanjpl If there is no serial number to see, then it is pr... Oct 6 2011, 11:15 PM
70_914
Did not know they existed til today when Bruce St... Oct 7 2011, 01:44 PM
Dave_Darling It probably matters for power. And you don't ... Oct 7 2011, 12:29 AM
rs182
It probably matters for power. And you don't... Oct 7 2011, 09:43 AM
rick 918-S
It probably matters for power. And you don... Oct 7 2011, 09:49 AM
rs182 will do. Some body can come get it if they want a ... Oct 7 2011, 09:57 AM
Cap'n Krusty As I believe I mentioned earlier, 72 bus engines h... Oct 7 2011, 01:47 PM
John Jentz
As I believe I mentioned earlier, 72 bus engines ... Oct 8 2011, 09:06 AM
brp986s I bought a new un #'d case maybe 15 yrs ago fr... Oct 7 2011, 08:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 04:42 AM |
