> Calling Eric Shea Brake Help Please, Is This Caliper Half Screwed ?
pilothyer
post Oct 6 2011, 09:58 PM
Today I started the disassembly of a pair of late rear brake calipers, drivers side no problem, both pistons screwed out and pulled out with no problem. The passenger side, however has some issues. The outer piston screwed out and pulled out without a problem. The inner piston was a different story. The teeth on the adjusting screw are broken. Am I screwed or is there some way to get the inner piston out. It is the teeth on the actual screw that are broken, not the removable piece that turns that screw...................Jerry
Eric_Shea
post Oct 7 2011, 11:39 AM
PMB Performance
Also... move the handbrake arm back and forth by (almost) any means possible. Watch to make certain that you do not snap off the bump stop.
This will move that "stuck" inner adjuster shaft by about 1/8" in its' bore breaking its' bond and allowing you to remove it without much trouble once you get the piston and adjuster mechanism out.
- Lo-Fi Version Time is now: 1st August 2025 - 12:38 PM
