| Radmacdaddy |
Oct 9 2011, 06:48 AM
Member ![]() ![]() Group: Members Posts: 83 Joined: 28-September 11 From: United States Member No.: 13,617 Region Association: None |
Ok, so an eArlier thread discussed ring without pulling an engine. Well I had no choice as when the valves I mentioned in my earlier thread acted up the strain pushed likely worn rings too far and I had to break her open.
All has gone very smoothly up until about midnite last night when after 1 1/2 hrs of trying to get the #2 cylinder back on over the rings (#1 went right on the new rings) the rings are not compressing enough to go on!!!! I could really use some urgent advice everyone! Btw, in a pinch, other than this glitch, the engine came apart in under an hour to the pistons. In the van. I recon I'd have had her back in no time, had this not happened. Thanks! |
| TheCabinetmaker |
Oct 9 2011, 07:29 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,375 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
You need to file the ends of the rings. One ring at a time. Take your time and be very careful removing and reinstalling the rings.
you should leave your entire trip in one thread. Three threads might get some important info missed. |
Radmacdaddy Urgent help needed to get cylinder back on! Oct 9 2011, 06:48 AM
vsg914 Where you at? Maybe someone close could come help... Oct 9 2011, 07:00 AM
Radmacdaddy I tried sanding them a bit, should I keep at it?
... Oct 9 2011, 07:12 AM
Radmacdaddy My brand new file didn't cut into them on firs... Oct 9 2011, 07:13 AM
Radmacdaddy ...also, how accurate do I need to be? Will they a... Oct 9 2011, 07:16 AM
vsg914 Oh yeah, file them just enough to fit in the cylin... Oct 9 2011, 07:32 AM
Radmacdaddy Do u mean in the gap? Those ends? They don't t... Oct 9 2011, 07:34 AM
vsg914 Yep. The gap between the ends of the rings when th... Oct 9 2011, 07:44 AM
Radmacdaddy So... I'm not sure you are getting me. If I pu... Oct 9 2011, 07:55 AM
rwilner
So... I'm not sure you are getting me. If I p... Oct 9 2011, 07:59 AM
Radmacdaddy Ok, thankfully have a 24 hour laundry matt beside ... Oct 9 2011, 08:23 AM
Radmacdaddy better description: Oct 9 2011, 08:26 AM
Radmacdaddy MUCH better pics... sorry. Oct 9 2011, 08:29 AM
vsg914 Ok. I'm with ya now. It appears you're rin... Oct 9 2011, 08:43 AM
Radmacdaddy It appears to be flush on the bottom 1/2, but like... Oct 9 2011, 08:50 AM
jsconst If you compress the ring and place it in the cylin... Oct 9 2011, 09:02 AM
Radmacdaddy Should I pop down to the auto store (open at 7am t... Oct 9 2011, 09:02 AM
jcd914
Should I pop down to the auto store (open at 7am ... Oct 9 2011, 11:24 AM
Radmacdaddy
If you compress the ring and place it in the cyli... Oct 9 2011, 09:04 AM
76-914 Either your ring compressor is catty wampus or wor... Oct 9 2011, 09:06 AM
sixnotfour If the ring is free in the groove, flip your ring... Oct 9 2011, 10:26 AM
Tom !/4" to 1/2" gap seems like an awful... Oct 9 2011, 12:28 PM
wingnut86 The old rings come in pretty handy for cleaning th... Oct 9 2011, 01:12 PM
vwsamba Take the ring off the piston, then put it in the c... Oct 9 2011, 02:11 PM
Radmacdaddy I got it! There was 1/16" of carbon on th... Oct 9 2011, 02:25 PM
messix
I got it! There was 1/16" of carbon on t... Oct 9 2011, 02:30 PM
KELTY360
I got it! There was 1/16" of carbon on t... Oct 9 2011, 03:08 PM
Radmacdaddy
I got it! There was 1/16" of carbon on ... Oct 9 2011, 03:21 PM
messix :confused: wondering if the bores are the same... ... Oct 9 2011, 02:28 PM
Radmacdaddy In my putting her back together, what might have g... Oct 9 2011, 02:53 PM
wingnut86 ...don't forget to stop and change that dang o... Oct 9 2011, 02:54 PM
Radmacdaddy
I got it! There was 1/16" of carbon on ... Oct 9 2011, 02:59 PM
wingnut86 ...burning oil past the rings - A LOT. Remember t... Oct 9 2011, 03:03 PM
Radmacdaddy
...burning oil past the rings - A LOT. Remember ... Oct 9 2011, 03:37 PM
wingnut86 The dots are your UP/DOWN guidance. Metallurgy an... Oct 9 2011, 03:06 PM
Radmacdaddy Is there anyone who would be willing to let me cal... Oct 9 2011, 03:06 PM
messix there are dots punched into the flat of the rings,... Oct 9 2011, 03:18 PM
Radmacdaddy I'm not sure if I've lost anybody who can ... Oct 9 2011, 06:34 PM
wingnut86 Rad,
Give me a buzz - I PM'd my cell # to you... Oct 9 2011, 06:55 PM
rick 918-S Do you still have the old rings? If so, break the ... Oct 9 2011, 09:50 PM
Radmacdaddy Ring side all set... on to proper TDC which I thin... Oct 9 2011, 09:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 07:11 PM |
