> Urgent help needed to get cylinder back on!, In the parking lot with engine open!
Radmacdaddy
post Oct 9 2011, 06:48 AM
Ok, so an eArlier thread discussed ring without pulling an engine. Well I had no choice as when the valves I mentioned in my earlier thread acted up the strain pushed likely worn rings too far and I had to break her open.
All has gone very smoothly up until about midnite last night when after 1 1/2 hrs of trying to get the #2 cylinder back on over the rings (#1 went right on the new rings) the rings are not compressing enough to go on!!!!
I could really use some urgent advice everyone!
Btw, in a pinch, other than this glitch, the engine came apart in under an hour to the pistons. In the van. I recon I'd have had her back in no time, had this not happened.
Thanks!
messix
post Oct 9 2011, 03:18 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
there are dots punched into the flat of the rings, as you look at the piston the dots on the rings point to the piston top, this orients the ring in the desired configuration. then the ring gaps need to be oriented as in a clock face: top ring 10 o'clock
second ring 2 o' clock thew 2 oil controls at 3 then 9 position.
Radmacdaddy   Urgent help needed to get cylinder back on!   Oct 9 2011, 06:48 AM
vsg914   Where you at? Maybe someone close could come help...   Oct 9 2011, 07:00 AM
Radmacdaddy   I tried sanding them a bit, should I keep at it? ...   Oct 9 2011, 07:12 AM
Radmacdaddy   My brand new file didn't cut into them on firs...   Oct 9 2011, 07:13 AM
Radmacdaddy   ...also, how accurate do I need to be? Will they a...   Oct 9 2011, 07:16 AM
vsg914   You need to file the ends of the rings. One ring a...   Oct 9 2011, 07:29 AM
vsg914   Oh yeah, file them just enough to fit in the cylin...   Oct 9 2011, 07:32 AM
Radmacdaddy   Do u mean in the gap? Those ends? They don't t...   Oct 9 2011, 07:34 AM
vsg914   Yep. The gap between the ends of the rings when th...   Oct 9 2011, 07:44 AM
Radmacdaddy   So... I'm not sure you are getting me. If I pu...   Oct 9 2011, 07:55 AM
rwilner   So... I'm not sure you are getting me. If I p...   Oct 9 2011, 07:59 AM
Radmacdaddy   Ok, thankfully have a 24 hour laundry matt beside ...   Oct 9 2011, 08:23 AM
Radmacdaddy   better description:   Oct 9 2011, 08:26 AM
Radmacdaddy   MUCH better pics... sorry.   Oct 9 2011, 08:29 AM
vsg914   Ok. I'm with ya now. It appears you're rin...   Oct 9 2011, 08:43 AM
Radmacdaddy   It appears to be flush on the bottom 1/2, but like...   Oct 9 2011, 08:50 AM
jsconst   If you compress the ring and place it in the cylin...   Oct 9 2011, 09:02 AM
Radmacdaddy   Should I pop down to the auto store (open at 7am t...   Oct 9 2011, 09:02 AM
jcd914   Should I pop down to the auto store (open at 7am ...   Oct 9 2011, 11:24 AM
Radmacdaddy   If you compress the ring and place it in the cyli...   Oct 9 2011, 09:04 AM
76-914   Either your ring compressor is catty wampus or wor...   Oct 9 2011, 09:06 AM
sixnotfour   If the ring is free in the groove, flip your ring...   Oct 9 2011, 10:26 AM
Tom   !/4" to 1/2" gap seems like an awful...   Oct 9 2011, 12:28 PM
wingnut86   The old rings come in pretty handy for cleaning th...   Oct 9 2011, 01:12 PM
vwsamba   Take the ring off the piston, then put it in the c...   Oct 9 2011, 02:11 PM
Radmacdaddy   I got it! There was 1/16" of carbon on th...   Oct 9 2011, 02:25 PM
messix   I got it! There was 1/16" of carbon on t...   Oct 9 2011, 02:30 PM
KELTY360   I got it! There was 1/16" of carbon on t...   Oct 9 2011, 03:08 PM
Radmacdaddy   I got it! There was 1/16" of carbon on ...   Oct 9 2011, 03:21 PM
messix   :confused: wondering if the bores are the same... ...   Oct 9 2011, 02:28 PM
Radmacdaddy   In my putting her back together, what might have g...   Oct 9 2011, 02:53 PM
wingnut86   ...don't forget to stop and change that dang o...   Oct 9 2011, 02:54 PM
Radmacdaddy   I got it! There was 1/16" of carbon on ...   Oct 9 2011, 02:59 PM
wingnut86   ...burning oil past the rings - A LOT. Remember t...   Oct 9 2011, 03:03 PM
Radmacdaddy   ...burning oil past the rings - A LOT. Remember ...   Oct 9 2011, 03:37 PM
wingnut86   The dots are your UP/DOWN guidance. Metallurgy an...   Oct 9 2011, 03:06 PM
Radmacdaddy   Is there anyone who would be willing to let me cal...   Oct 9 2011, 03:06 PM
messix   there are dots punched into the flat of the rings,...   Oct 9 2011, 03:18 PM
Radmacdaddy   I'm not sure if I've lost anybody who can ...   Oct 9 2011, 06:34 PM
wingnut86   Rad, Give me a buzz - I PM'd my cell # to you...   Oct 9 2011, 06:55 PM
rick 918-S   Do you still have the old rings? If so, break the ...   Oct 9 2011, 09:50 PM
Radmacdaddy   Ring side all set... on to proper TDC which I thin...   Oct 9 2011, 09:53 PM
- Lo-Fi Version Time is now: 14th April 2026 - 07:11 PM
