| DRPHIL914 |
Oct 11 2011, 09:17 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,889 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
I used to see a little bit , a few drops here and there, but now since changing to the Brad Penn have a mess on the garage floor
Not sure where from but seems it could be from the oil cooler seal? i cant really see for sure. i dont see any major leaking from the push rod tube seals, but these should be replaced anyway, they look original - car is 75 2.0, i have lots of documents from p.o's but nothing to show any problems here before- I have had it for 2 years., only about 2,000 miles on it since then, but about 130,000 on the original engine, - good compression , car runs good now that the F.I has been competely redone. just wondering if the oil change could have been part of the issue - i was using a straight weight conventional oil . maybe about 500miles of driving with the brad penn, - did notice it right away, and not coming from the filter. pw. |
| wingnut86 |
Oct 11 2011, 01:26 PM
...boola la boo boola boo... ![]() ![]() ![]() Group: Members Posts: 1,054 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
same thoughts up here Phil.
You removed the cheap stuff and added liquid gold, now the lead pipes need replacing as well. Lots of spare stuff on the 2.0 in pieces in the garage Noting the cylinders/pistons/rings/push rods/adjusters are shot - otherwise, all good. (IMG:style_emoticons/default/biggrin.gif) |
Philip W. Oil leak after changing to Brad Penn oil? Oct 11 2011, 09:17 AM
ConeDodger It is probably just time to re-seal the motor. I d... Oct 11 2011, 10:00 AM
tradisrad before you condem the oil cooler seals you should ... Oct 11 2011, 10:32 AM
SUNAB914 Hey Phil, make sure you tightened the drain plug... Oct 11 2011, 01:25 PM
Philip W.
Hey Phil, make sure you tightened the drain plug... Oct 11 2011, 01:55 PM
Philip W.
You removed the chea... Oct 11 2011, 01:54 PM
rmital
.... Im told the synthetic has smaller molecules,... Oct 11 2011, 02:08 PM
Drums66
.... Im told the synthetic has smaller molecules... Oct 11 2011, 03:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 5th March 2026 - 08:45 AM |
