| mgphoto |
Sep 28 2011, 05:56 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,511 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
The time has come to rebuild the original EA motor in my '72.
I am most of the way though teardown, I will add some photos of the worn parts in a later post. I am trying to figure out the size of the tool to use to remove this fastener, the cover for the second oil pressure relief piston and spring. ![]() Factory service manual has it as M14 internal head socket. I searched for it but all I could find is the AST Tool # S 54 X-14 at the link listed below http://www.asttool.com/detail_page.php?too...r=S%2054%20X-14 Does anyone know if this is the correct tool? Thanks for looking, Mike |
| mgphoto |
Oct 13 2011, 06:13 PM
OK got the case back after cleaning and tapping the oil galleys.
![]() more photos to come... |
mgphoto High Mileage EA motor teardown Sep 28 2011, 05:56 PM
vsg914 If I recall correctly, its the same tool you use f... Sep 28 2011, 06:06 PM
mgphoto Hey vsg914, just checked and the axle tool is much... Sep 28 2011, 06:15 PM
RON S. When I needed an internal 12pt tool for my CV... Sep 28 2011, 06:20 PM
'73-914kid 3/8 inch drive socket extension worked for me....i... Sep 28 2011, 06:20 PM
vsg914 You are correct. Its called a tripple square, amon... Sep 28 2011, 06:24 PM
mgphoto
You are correct. Its called a tripple square, amo... Sep 28 2011, 09:36 PM
rick 918-S Wow! 330K? Very cool! :popcorn: Sep 28 2011, 09:50 PM
76-914
That... Sep 29 2011, 04:48 PM
McMark Yup, never used anything but a 3/8" drive ext... Sep 28 2011, 11:17 PM
mgphoto I ran into a small snag, trying to remove the head... Sep 29 2011, 12:25 PM
Jake Raby To remove that triple square fastener give it two ... Sep 29 2011, 05:12 PM
mgphoto I bought the car in the '80's, 96k on the ... Sep 30 2011, 06:46 PM
Valy
Pulled the motor at 337,xxx broke 2 angle drives ... Sep 30 2011, 07:12 PM
76-914
[quote name='mgphoto' post='1547261... Oct 1 2011, 11:48 AM
mgphoto I took the case over to Engine Machine Services, t... Oct 5 2011, 01:27 PM
r_towle Dont glass bead it, you wont see it after you buil... Oct 5 2011, 01:35 PM
mgphoto
Dont glass bead it, you wont see it after you bui... Oct 5 2011, 04:16 PM
mgphoto OK dismantled the heads, there is one odd item, on... Oct 12 2011, 06:22 PM
Vacca Rabite That is an intake valve guide dropping into the he... Oct 12 2011, 06:50 PM
mgphoto
That is an intake valve guide dropping into the h... Oct 13 2011, 06:10 PM
HAM Inc That head with the dropping intake valve guide has... Oct 13 2011, 07:03 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th November 2026 - 12:55 PM |
