> V8 Conversion Owners...what springs?, Looking to stiffen my ride!
streetrover
post Oct 15 2011, 09:45 PM
Took my "in progress" v8 conversion out for a spin the other day. 4.0 liter aluminum v8 from Range Rover. Ran strong but stock suspension was very spongy. Felt like driving mom's Buick. What have you done to retain the wonderful stiffness and handling of the original 914?
streetrover
post Oct 17 2011, 11:01 PM
Great feedback so far! Generally this car is to be used as a daily driver. I drive 80 miles round-trip to and from work through the Cajon Pass in sunny So Cal. I've modified the trans with high (H) freeway gears, Occasionally would like to spend a Saturday or two each month enjoying a run around the local mountain roads at elevated speeds. (IMG:style_emoticons/default/biggrin.gif)
I'm not intending to spend any time on the track ... ever.
So...does anyone have a deal on a pair of these stiffer springs? Say 200 lbs to start. Sway Bars?
I'm also a bit confused...am I to understand the front suspension employs torsion bars? I know the rear is supported by coil springs and NOT torsion bars (like torsion bars on the VW's). I thought the fronts used struts that provided suspension and suspension dampening simultaneously. (IMG:style_emoticons/default/confused24.gif)
BTW...stock fenders and wheels.
Ohh and here's a little added info from wikipedia about the weight of the engine.
"Known variously as the Fireball and Skylark by Buick (and as Rockette, Cutlass, and Turbo-Rocket by Oldsmobile),[3] the 215 had a 4.24 in (108 mm) bore spacing, a bore of 3.5 in (89 mm), and a stroke of 2.8 in (71 mm), for an actual displacement of 215.5 cu in (3,531 cc). The engine was the lightest mass-production V8 in the world, with a dry weight of only 318 lb (144 kg). Measuring 28 in (71 cm) long, 26 in (66 cm) wide, and 27 in (69 cm) high (same as the small-block Chevy)[4] it was standard equipment in the 1961 Buick Special."
Bob
streetrover   V8 Conversion Owners...what springs?   Oct 15 2011, 09:45 PM
Bruce Hinds   It's been a while, I don't trust my memory...   Oct 15 2011, 10:18 PM
jimkelly   someone here talked about this set up recently but...   Oct 15 2011, 10:20 PM
kg6dxn   I used 180lb progressive springs on my last one an...   Oct 15 2011, 10:24 PM
stewteral   Took my "in progress" v8 conversion out...   Oct 15 2011, 10:53 PM
914junkie   200lb Eibach springs with Koni adjustable shocks o...   Oct 16 2011, 03:18 AM
rick 918-S   180 progressive rears. I need to add a rear bar bu...   Oct 16 2011, 07:07 AM
computers4kids   Took my "in progress" v8 conversion out...   Oct 16 2011, 09:00 AM
Andyrew   On the street 180s if you want a cushy/safe ride, ...   Oct 16 2011, 09:19 AM
sean_v8_914   this can not be answered well until you tell us ho...   Oct 16 2011, 10:55 AM
stewteral   this can not be answered well until you tell us h...   Oct 16 2011, 11:50 AM
stewteral   Took my "in progress" v8 conversion out...   Oct 16 2011, 11:48 AM
Andyrew   Im not sure I would recommend 22 front tbars on a ...   Oct 16 2011, 12:09 PM
stewteral   Im not sure I would recommend 22 front tbars on a...   Oct 17 2011, 09:59 PM
Bruce Hinds   All that discussion on spring rate is interesting,...   Oct 17 2011, 10:41 PM
stewteral   All that discussion on spring rate is interesting...   Oct 18 2011, 12:50 PM
Bruce Hinds   All that discussion on spring rate is interestin...   Oct 18 2011, 01:52 PM
stewteral   [quote name='stewteral' post='1556961' date='Oct ...   Oct 18 2011, 10:41 PM
Bruce Hinds   Bruce, Trailing throttle oversteer, now that is a...   Oct 19 2011, 10:38 AM
messix   all you guys are quoting spring rates for a iron s...   Oct 17 2011, 10:50 PM
streetrover   Great feedback so far! Generally this car is ...   Oct 17 2011, 11:01 PM
stewteral   Great feedback so far! Generally this car is...   Oct 18 2011, 01:05 PM
messix   front t/bars run thru the arms front to back. str...   Oct 17 2011, 11:14 PM
Andyrew   Bob, Im going to reiterate my statement earlier. ...   Oct 18 2011, 01:01 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:30 PM
