| streetrover |
Oct 15 2011, 09:45 PM
Member ![]() ![]() Group: Members Posts: 87 Joined: 22-December 09 From: Inland Empire Member No.: 11,163 Region Association: Southern California |
Took my "in progress" v8 conversion out for a spin the other day. 4.0 liter aluminum v8 from Range Rover. Ran strong but stock suspension was very spongy. Felt like driving mom's Buick. What have you done to retain the wonderful stiffness and handling of the original 914?
| Bruce Hinds |
Oct 17 2011, 10:41 PM
V-8 madness ![]() ![]() ![]() Group: Members Posts: 763 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
All that discussion on spring rate is interesting, but some of it depends too on how much tire he's going to be running.
300-400 lb springs would feel a lot softer with big meats under wide flares but probably feel like riding on bricks in a narrow body with 205/60s. The other thing mentioned is all the extra weight. 250 lbs is not that much extra weight. My SBC is just over 300 hp and i'm running 2oo lb springs, stock sway bar in the rear and a 911 bar up front, 22mm I think. The tires are 215/60s all the way around on 15x6 front and 15x7s rear. I used to drive 34 miles of canyon road to Estes Park, Colo every week and it was just a HOOT. It was a perfect balance and I could steer it with throttle on the increasing and decreasing radius turns. It all just has to balance to get a nice combination you like. (IMG:style_emoticons/default/driving.gif) |
| stewteral |
Oct 18 2011, 12:50 PM
Old Member ![]() ![]() Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
All that discussion on spring rate is interesting, but some of it depends too on how much tire he's going to be running. 300-400 lb springs would feel a lot softer with big meats under wide flares but probably feel like riding on bricks in a narrow body with 205/60s. The other thing mentioned is all the extra weight. 250 lbs is not that much extra weight. My SBC is just over 300 hp and i'm running 2oo lb springs, stock sway bar in the rear and a 911 bar up front, 22mm I think. The tires are 215/60s all the way around on 15x6 front and 15x7s rear. I used to drive 34 miles of canyon road to Estes Park, Colo every week and it was just a HOOT. It was a perfect balance and I could steer it with throttle on the increasing and decreasing radius turns. It all just has to balance to get a nice combination you like. (IMG:style_emoticons/default/driving.gif) Hey Bruce, Just for reference: my car runs 315/35-17 Hoosier DOT Slicks with a very stiff racing carcass. For a SOFTER ride, I'd go with your 215/60 tires with a tall, soft sidewall. Even on the Hoosiers, the ride would not upset the wife with 300 lb springs. Secondly: the issue of weight is not just about lbs for a 914, it's about TALL weight that makes the car want to roll in corners. The 914 was designed with a low CG of a V8 engine and a low-roll chassis. After bump-steering all 4 corners, I learned that the rear suspension TOES-IN .100" for each inch of compression (the loaded tire in a corner) while the other wheel TOES-OUT the same .100" as the unloaded wheel. This means BOTH rear wheels turn toward the center of the corner in roll. Thus, understeer is guaranteed unless mods are made. My guess is that Porsche wanted to be SURE of no oversteer in the era of Ralph Nader. I'm glad you like the balance of your car, but have a question about balance: With narrow tires, are you changing the handling with the trottle (power induced oversteer)? If you were to take a corner on the limit at 50-60 on a steady , slightly-positive throttle, what would the car do? Would it be neutral, understeering or oversteering? -- I'm thinking understeer, but since U/S is stable, it's not a bad thing and especially if you like it. My case is very different: I'm trying to micro-tune the chassis balance for the max cornering speed on track and I HATE understeer. (IMG:style_emoticons/default/smile.gif) Happy motoring on those Colorado roads! Terry |
| Bruce Hinds |
Oct 18 2011, 01:52 PM
All that discussion on spring rate is interesting, but some of it depends too on how much tire he's going to be running. 300-400 lb springs would feel a lot softer with big meats under wide flares but probably feel like riding on bricks in a narrow body with 205/60s. The other thing mentioned is all the extra weight. 250 lbs is not that much extra weight. My SBC is just over 300 hp and i'm running 2oo lb springs, stock sway bar in the rear and a 911 bar up front, 22mm I think. The tires are 215/60s all the way around on 15x6 front and 15x7s rear. I used to drive 34 miles of canyon road to Estes Park, Colo every week and it was just a HOOT. It was a perfect balance and I could steer it with throttle on the increasing and decreasing radius turns. It all just has to balance to get a nice combination you like. (IMG:style_emoticons/default/driving.gif) Hey Bruce, Just for reference: my car runs 315/35-17 Hoosier DOT Slicks with a very stiff racing carcass. For a SOFTER ride, I'd go with your 215/60 tires with a tall, soft sidewall. Even on the Hoosiers, the ride would not upset the wife with 300 lb springs. Secondly: the issue of weight is not just about lbs for a 914, it's about TALL weight that makes the car want to roll in corners. The 914 was designed with a low CG of a V8 engine and a low-roll chassis. After bump-steering all 4 corners, I learned that the rear suspension TOES-IN .100" for each inch of compression (the loaded tire in a corner) while the other wheel TOES-OUT the same .100" as the unloaded wheel. This means BOTH rear wheels turn toward the center of the corner in roll. Thus, understeer is guaranteed unless mods are made. My guess is that Porsche wanted to be SURE of no oversteer in the era of Ralph Nader. I'm glad you like the balance of your car, but have a question about balance: With narrow tires, are you changing the handling with the trottle (power induced oversteer)? If you were to take a corner on the limit at 50-60 on a steady , slightly-positive throttle, what would the car do? Would it be neutral, understeering or oversteering? -- I'm thinking understeer, but since U/S is stable, it's not a bad thing and especially if you like it. My case is very different: I'm trying to micro-tune the chassis balance for the max cornering speed on track and I HATE understeer. (IMG:style_emoticons/default/smile.gif) Happy motoring on those Colorado roads! Terry hey Terry, I miss the colorado roads, we left there many years ago. I can't really answer your question about the understeer or over, It was just a delight on the mountain roads. I can remember putting down the power in the turns and lifting it would trun in slightly and adding power the back end would squat just a little and straighten out some. I know 205/60s on the front 15x6 wheels is a little large and I may have had a better foot print if I'd used 205s. Over all though is was a blast. I know what you mean by the low CG... I did some auto cross while I was in CO and a nice set up 2 litre would clean my clock. I know my car was way more fun on those mountain roads, because I'd also done it in a '73 2.0LE that I'd had hotrodded by Sims in Dallas before I built the V8 car. Lowering the car some helps and I imagine the little alum. buick will be a nice set up. |
streetrover V8 Conversion Owners...what springs? Oct 15 2011, 09:45 PM
Bruce Hinds It's been a while, I don't trust my memory... Oct 15 2011, 10:18 PM
jimkelly someone here talked about this set up recently but... Oct 15 2011, 10:20 PM
kg6dxn I used 180lb progressive springs on my last one an... Oct 15 2011, 10:24 PM
stewteral
Took my "in progress" v8 conversion out... Oct 15 2011, 10:53 PM
914junkie 200lb Eibach springs with Koni adjustable shocks o... Oct 16 2011, 03:18 AM
rick 918-S 180 progressive rears. I need to add a rear bar bu... Oct 16 2011, 07:07 AM
computers4kids
Took my "in progress" v8 conversion out... Oct 16 2011, 09:00 AM
Andyrew On the street 180s if you want a cushy/safe ride, ... Oct 16 2011, 09:19 AM
sean_v8_914 this can not be answered well until you tell us ho... Oct 16 2011, 10:55 AM
stewteral
this can not be answered well until you tell us h... Oct 16 2011, 11:50 AM
stewteral
Took my "in progress" v8 conversion out... Oct 16 2011, 11:48 AM
Andyrew Im not sure I would recommend 22 front tbars on a ... Oct 16 2011, 12:09 PM
stewteral
Im not sure I would recommend 22 front tbars on a... Oct 17 2011, 09:59 PM
stewteral
[quote name='stewteral' post='1556961' date='Oct ... Oct 18 2011, 10:41 PM
Bruce Hinds Bruce,
Trailing throttle oversteer, now that is a... Oct 19 2011, 10:38 AM
messix all you guys are quoting spring rates for a iron s... Oct 17 2011, 10:50 PM
streetrover Great feedback so far! Generally this car is ... Oct 17 2011, 11:01 PM
stewteral
Great feedback so far! Generally this car is... Oct 18 2011, 01:05 PM
messix front t/bars run thru the arms front to back.
str... Oct 17 2011, 11:14 PM
Andyrew Bob, Im going to reiterate my statement earlier.
... Oct 18 2011, 01:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:55 PM |
