| Radmacdaddy |
Oct 10 2011, 12:23 AM
Member ![]() ![]() Group: Members Posts: 83 Joined: 28-September 11 From: United States Member No.: 13,617 Region Association: None |
I'm viewing the great valve adjustment article over at pelican & have my one wheel off the ground to get it just right but I have no viewing ports into my flywheel.
How then can I get the tdc worked out? I did the straw in the #1 cylinder trick too, put it in & note when it is most pushed out and before it goes back into the chamber... But it still feels like its not just right. Thought? |
| BigDBass |
Oct 19 2011, 06:30 PM
Dumb Question Champion ![]() ![]() ![]() Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
This thread is something else..
(IMG:style_emoticons/default/popcorn[1].gif) Best of luck and huge props on this adventure. (IMG:style_emoticons/default/pray.gif) |
Radmacdaddy Tdc with no viewing ports? Oct 10 2011, 12:23 AM
PancakePorsche I marked my fan with 180 degree mark painted a dif... Oct 10 2011, 12:31 AM
vwsamba TDC is not THAT critical for setting the valves, j... Oct 10 2011, 02:17 AM
mikea100
I'm viewing the great valve adjustment articl... Oct 10 2011, 07:27 AM
r_towle TDC is not something to worry about when adjusting... Oct 10 2011, 07:40 AM
Radmacdaddy
TDC is not something to worry about when adjustin... Oct 10 2011, 09:08 AM
r_towle It not possible to install the distributor 180 deg... Oct 10 2011, 09:13 AM
Radmacdaddy I only have carb feeding both sides.
Ok, so notc... Oct 10 2011, 09:19 AM
r_towle you are at TDC when the Intake valve is just about... Oct 10 2011, 09:22 AM
Radmacdaddy Looks like I've been real close to tdc all alo... Oct 10 2011, 09:29 AM
r_towle loose is good, loud but safe, tight will make you ... Oct 10 2011, 09:38 AM
Radmacdaddy
loose is good, loud but safe, tight will make you... Oct 10 2011, 09:55 AM
Radmacdaddy So, I have hydraulic valves. Tom Wilson says 2 tur... Oct 10 2011, 09:46 AM
So, I have hydraulic valves. Tom Wilson says 2 tu... Oct 10 2011, 11:04 AM
Radmacdaddy
[quote name='Radmacdaddy' post='1552153' date='Oc... Oct 10 2011, 11:14 AM
wingnut86 Great detail in there guys.
Randy - After you get... Oct 10 2011, 09:49 AM
r_towle for a rough setup, yes that is right Oct 10 2011, 09:56 AM
Radmacdaddy Ok, I'm adjusted. Now the firing.
I see in m... Oct 10 2011, 10:27 AM
Radmacdaddy r_towle... you've given some REALLY useful inf... Oct 10 2011, 11:17 AM
messix Check the spark plug wires, do you have a volt ohm... Oct 10 2011, 11:33 AM
Radmacdaddy
Check the spark plug wires, do you have a volt oh... Oct 10 2011, 11:40 AM
wingnut86 Randy,
If you want to verify the cable suggestion... Oct 10 2011, 01:12 PM
r_towle So,
You think you have the valves sorted.
What mak... Oct 10 2011, 01:38 PM
wingnut86 Rad,
Are you making headway?
Rolling towards Cal... Oct 10 2011, 09:06 PM
Radmacdaddy So, thanks to R_towle's great advise I rebuilt... Oct 11 2011, 11:49 AM
Radmacdaddy I just flew out to Ariz to buy a vanagon and drive... Oct 11 2011, 12:00 PM
URY914 RE: Tdc with no viewing ports? Oct 11 2011, 12:26 PM
r_towle so,
Can he get it running perfect?
Enough to drag ... Oct 11 2011, 12:42 PM
wingnut86 if not, he can add a NOS bottle and FLY the rest o... Oct 11 2011, 01:22 PM
wingnut86 RMD,
Any update on the repairs? Just wondering s... Oct 11 2011, 02:55 PM
KELTY360 Did the heavy smoke dissipate? Oct 11 2011, 07:27 PM
Radmacdaddy My trip from Phoenix to Show low(where I bought th... Oct 12 2011, 05:16 AM
wingnut86 Reach out here or on TheSamba and have a set of sp... Oct 12 2011, 05:41 AM
vsg914 There are several 914 guys in Albuquerque who coul... Oct 12 2011, 07:35 AM
vsg914 Also, the Bughaus (one of the largest internet vw ... Oct 12 2011, 07:37 AM
Radmacdaddy New Carb pics...
just installed, going for a test... Oct 12 2011, 11:08 AM
vsg914 Why the rtv? Oct 12 2011, 11:49 AM
r_towle Randy,
Go this way home....
Check it out...
http:... Oct 12 2011, 01:35 PM
wingnut86 He's out of Duct Tape...
<grin> Oct 12 2011, 01:36 PM
Radmacdaddy What's rtv?
I did one hell of a repair on the... Oct 12 2011, 05:49 PM
Dave_Darling
What's rtv?
Room Temperature Vulcanizing sil... Oct 12 2011, 07:02 PM
r_towle Who lives near albuquerque new Mexico?
Randy needs... Oct 12 2011, 06:58 PM
Radmacdaddy Made it to NM!!!!! Wahoo!... Oct 12 2011, 07:09 PM
wingnut86 2.0 rebuild kit will have all the seals you need, ... Oct 12 2011, 07:50 PM
Radmacdaddy Well... Based on compression on #3-70lbs, down fro... Oct 12 2011, 09:25 PM
Radmacdaddy Posted: Today 12:09 am Post subject:
r_towle... Oct 13 2011, 11:13 PM
jcd914 You're not likely to have good compression on ... Oct 14 2011, 01:19 AM
wingnut86 Randy,
If you can run it in the car for an hour o... Oct 14 2011, 05:48 AM
Radmacdaddy So, I spent two full days rebuilding the engine un... Oct 15 2011, 06:30 PM
wingnut86 Randy,
You should volunteer to do the next valve ... Oct 15 2011, 07:50 PM
Radmacdaddy Wouldn't you know... I'm driving in OK and... Oct 15 2011, 11:12 PM
messix You have got to put this all in to a jornal . or w... Oct 15 2011, 11:45 PM
r_towle Randy made it to somewhere between Memphis and Nas... Oct 17 2011, 10:29 AM
wingnut86 Randy,
You can have the GC 2.0 case I currently h... Oct 17 2011, 11:27 AM
Radmacdaddy As rich mentioned, the case is blown, I have about... Oct 17 2011, 03:05 PM
Radmacdaddy crank case damage:
http://www.914world.com/bbs2/up... Oct 17 2011, 06:30 PM
wingnut86 Don't toss the case Randy. They aren't bu... Oct 17 2011, 07:10 PM
Radmacdaddy Thanks Dave, a shipping price would be great.
I... Oct 18 2011, 09:07 PM
wingnut86 Good luck Rad man. I'LL have pricing by Monda... Oct 18 2011, 09:09 PM
Radmacdaddy Can someone look at this case and tell me what eng... Oct 19 2011, 06:08 PM
messix the plenum looks like a 1.8 l-jet, i think it has ... Oct 19 2011, 06:13 PM
wingnut86 Randy,
See if the seller can check 2 points on th... Oct 19 2011, 08:07 PM
Dave_Darling I don't see the 914 dipstick tube. Not sure i... Oct 19 2011, 09:56 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:05 AM |
