engine specs!, big four!!!!!! |
kid914 |
Oct 20 2011, 02:56 PM
ALWAYS lead...NEVER follow!!!! Group: Members Posts: 2,534 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada |
I hope someone can help me.
I would like to rubuild my type IV INTO A BIG FOUR. I am wondering if anyone who's done it has ...or know;s someone who has a complete engine specs sheet to share.. (IMG:style_emoticons/default/drunk.gif) Any help is greatly appreciated. kid914 |
VaccaRabite |
Oct 20 2011, 03:07 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
How big is big, and how much do you want to spend.
If this is your first time with an engine build, I'd suggest doing a 2056 (or 1911 of your car is a 1.7 or 1.8). It keeps many of the stock parts, gives a nice bump to HP and torque. Many of the pros here will tell you that you don't want to go with a bore size over 96mm if you keep the cast iron cylinders - and make more displacement through stroke. If you want to stay with stock FI, you need to keep the cam mild - stock really. Carbs will allow for bigger cams and bigger compression (as will modern EFI). And the cost to build a big 4 still is not super cheap. a 2056 will probably set you back about 3K if you can reuse some things. 1/2 of that cost is head work. So, what do you want, and what is your budget? Zach |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:08 AM |
