Can this be cleaned |
914itis |
Oct 20 2011, 07:45 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Can this distributor be cleaned? it looks preety dirty and somewhat rusty inside. How do I clwan it?
Andyrew |
Oct 20 2011, 07:59 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Anything electrical in there or just mechanical? Carb cleaner would probably break apart most of it.
But I havent touched those dizzy's in years so I dont know if it would be bad for it or not.. |
Valy |
Oct 21 2011, 12:20 AM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
slu234 |
Oct 21 2011, 07:45 AM
Member Group: Members Posts: 57 Joined: 20-January 09 From: Staunton, VA Member No.: 9,949 Region Association: MidAtlantic Region |
The little "green" wire is the grounding strap to ground the points plate to the dizzy body. If it is toast you can buy some de-soldering floss and solder in a replacement. The desoldering floss is a flat braid of fine copper - soft flexible and works great.
Brian |
Jasfsmith |
Oct 21 2011, 08:59 AM
Senior Member Group: Members Posts: 556 Joined: 4-October 04 From: Bangor, ME Member No.: 2,882 Region Association: North East States |
The little "green" wire is the grounding strap to ground the points plate to the dizzy body. If it is toast you can buy some de-soldering floss and solder in a replacement. The desoldering floss is a flat braid of fine copper - soft flexible and works great. Brian I've never seen the grounding strap having a sheath on it. I suspect the strap is the original braided copy that has oxidized to the color green. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:56 PM |
