Need some help picking an adequate amp |
computers4kids |
Oct 23 2011, 08:39 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Recently changed my pod speakers to the ones below and primarily just use my phone or ipod. Pretty much never listen to the radio. No amp.
I've come to the point I would like some more volume and quality sound and would like to add an amp and a sub--need your help. I don't want to cut my doors for more speakers. Hopefully a foot sub or console sub with these speakers will be adequate for me. I'm thinking of mounting a amp in my center arm rest with a little modification or behind the driver seat. I don't want to mount the amp in the trunks. Can you help me know what size amp (RMS) I need as a minimum, number of channels, and do I need a premamp. The guy at the stereo store said I need a premamp if I want really good sound without static?? Speak slowly...I am not a stereo guy LOL (IMG:style_emoticons/default/smile.gif) Polk Audio - 4" x 6" Plate-Mounted Speakers with Poly-Mica Composite Cones (Pair) Handles up to 150W peak power (50W RMS) For rich sound. 71Hz - 22kHz frequency response For accurate sound reproduction. 3/4" silk/polymer soft dome tweeter Delivers clear, well-defined highs. 4" x 6" poly-mica composite woofer cones and rubber surrounds For enhanced bass response. The stiff, lightweight design delivers big sound and minimal distortion. 4 ohms impedance Conducts power evenly to keep the speaker at an appropriate level. 91dB sensitivity Picks up the highs and lows for faithful sound reproduction. Balance Driver technology For pure sound. Pole Plate heat sink Promotes heat dissipation for great power handling and reliability. (IMG:http://www.914world.com/bbs2/uploads/post-4253-1257311673.jpg) |
computers4kids |
Oct 23 2011, 10:50 AM
Thanks. When you bridge to channels together do you get the RMS watts of both channels added together or less?
My last car I had used y connectors to connect a 2 channel amp. Is a kit like the one below worth the effort to gain an external volume control separate than the ipod? Currently I have a cable that charges my ipod as well as sends the signal to my period correct radio. Attached image(s) |
underthetire |
Oct 23 2011, 10:59 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Thanks. When you bridge to channels together do you get the RMS watts of both channels added together or less? My last car I had used y connectors to connect a 2 channel amp. Is a kit like the one below worth the effort to gain an external volume control separate than the ipod? Currently I have a cable that charges my ipod as well as sends the signal to my period correct radio. Might be a nice option, less adapters and your iPod will never go dead. Not sure the volume control would be handy or not. How much is that kit? |
Lo-Fi Version | Time is now: 10th June 2024 - 05:43 AM |
