Progress, The 2011 Hershey show gave me another shot of motivation |
saigon71 |
May 2 2011, 07:33 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I have now attended the Hershey Porsche show three times without an operational teener...NOT being part of the caravan is getting old. (IMG:style_emoticons/default/mad.gif)
Finally got my new inner long welded in with doubler plates on all seams. Verified the incline of the new long with an incline gauge (with the car level) following Jeff Hails build thread. Door operates well! Entire inner long has been coated with rust encapsulator. Still have a long way to go but I am hoping that this was the toughest part. Thanks to Scotty B, Jeff Hail, and everyone else who has posted a build thread on this topic. I have read all of them & learned a lot. (IMG:style_emoticons/default/beerchug.gif) Bob |
saigon71 |
Oct 26 2011, 08:14 PM
Got the inner suspension console tack welded in place today.
Figured out the slight rock I had in the piece was from two previous rosette welds on the new longitudinal not ground completely flush. I spent quite a bit of time bending, hammering and adjusting the areas to be welded on this piece, to make sure it fit as good as possible. There is a slight gap at the top of suspension console that will be addressed with a big hammer and block of wood after the rest of it is tacked on. Took one more measurement, from both the front and rear firewall, dead on both ways. I started with the leading edge, because of the alignment mark. I was amazed to see how much the whole console moved forward from two tack welds! Re-checked the measurements and they were off. Had to grind off the spot welds with a dremmel tool and start over again. The trailing edge needed some side pressure before tacking it on, so I broke out the special tools. Needed to put a little pressure on the bottom of the console before tacking the bottom on. |
Lo-Fi Version | Time is now: 4th June 2024 - 10:38 AM |
