| bandjoey |
Oct 27 2011, 04:36 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I'm getting ready to install Mikey's new rubber seals in the engine compartment. Getting the old hardened ones out took cutting and chiseling. Ug.
What's the preferred method to install the new seals into the channels? Oil it all up and slide it in? Align it and squish it in inch by inch? Other ways? Thanks. |
| Katmanken |
Oct 27 2011, 05:05 PM
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
If you slide, use lots of lube.
I put the bottom of the rubber in the bottom of the retaining bracket, and carefully used a screwdriver to work the top in. Other methods may vary.... |
bandjoey Preferred Method of install Engine Tin Seals Oct 27 2011, 04:36 PM
dlee6204
:agree:
I used this method and it worked fine... Oct 27 2011, 05:10 PM
:agree:
I used this method and it worked fine... Oct 27 2011, 05:29 PM
Vacca Rabite :agree:
it goes pretty quick.
Zach Oct 27 2011, 05:31 PM
Mikey914 I used the big screwdriver method, but I guess you... Oct 27 2011, 08:25 PM
sean_v8_914 DO NOT SLIDE IT IN!
the stretch will turn to s... Oct 27 2011, 08:30 PM
rwilner I just did this and used the push / slide method, ... Oct 27 2011, 09:44 PM
bandjoey Thanks. I'll try the top to bottom method firs... Oct 27 2011, 11:03 PM
914_teener
Thanks. I'll try the top to bottom method fir... Oct 28 2011, 10:41 AM
vsg914 I first tried to slide mine in with wd40. Nope. Th... Oct 28 2011, 10:59 AM
r_towle Screw driver....simplest way Oct 28 2011, 06:51 PM
Eric_Shea I used a wooden pick:
https://fbcdn-sphotos-a.aka... Oct 28 2011, 07:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd March 2026 - 08:40 PM |
