> Making top of door window match targa rubber, Alignment issue
PanelBilly
post Oct 27 2011, 04:34 PM
Maybe I can post a photo to explain this better, but the side glass doesn't go high enough to seal to the rubber. I have new seals rom 914 Rubber, but the glass doesn't go high enough to fit right. I know I can adjust the window to raise higher, but then it will go above the rubber stop on top of the crome guide that holds in the wing glass. The chrome trip is held in place by a bolt in the base of the door and another inside the door. It doesn't adjust up and down. Tell me where I have this adjustment out of wack. Could it be that the rubber seal needs to be thicker. Should I have a filler between the seal and the targa top?
VaccaRabite
post Oct 27 2011, 05:33 PM
En Garde!
one of 4 things has happened.
1: the window is not properly aligned in the door.
2: the door is not properly aligned in the car.
3: you have a late roof and an early car, or an early car and a late roof
4: chassis twist (not likely with yours I think.)
Zach
PanelBilly   Making top of door window match targa rubber   Oct 27 2011, 04:34 PM
Vacca Rabite   one of 4 things has happened. 1: the window is not...   Oct 27 2011, 05:33 PM
7TPorsh   I have this same problem...early car....hmmm :head...   Oct 27 2011, 05:39 PM
ellisor3   I had the same issue. Mine was short about 1/4 inc...   Oct 27 2011, 05:40 PM
Mikey914   The seals were replicated from the late OEM as the...   Oct 27 2011, 06:12 PM
jim912928   Adjustment advice would be much appreciated....min...   Oct 27 2011, 08:14 PM
Mikey914   Most of the adjustment is in the door. Mostly a fu...   Oct 27 2011, 08:21 PM
Seaside6   I have the same issue with newly installed 914rubb...   Oct 27 2011, 09:00 PM
Philip W.   I have the same issue with newly installed 914rub...   Oct 28 2011, 07:41 AM
Philip W.   I have the same issue with newly installed 914rub...   Oct 28 2011, 07:52 AM
ThinAir   :ttiwwp: Most of the time that's just a joke t...   Oct 27 2011, 09:42 PM
ppetion   This is exactly the issue that I was dealing with ...   Oct 27 2011, 10:25 PM
ellisor3   If it is leaning towards the interior, the seals a...   Oct 28 2011, 04:42 AM
jim_hoyland   Phil, What width 3M double sided tape are you usin...   Oct 28 2011, 08:00 AM
Philip W.   Phil, What width 3M double sided tape are you usi...   Oct 28 2011, 11:02 AM
jim_hoyland   Phil, What width 3M double sided tape are you us...   Oct 28 2011, 03:34 PM
Philip W.   [quote name='Philip W.' post='1562862' date='Oct ...   Oct 28 2011, 03:47 PM
r_towle   Maybe I can post a photo to explain this better, ...   Oct 28 2011, 08:10 AM
andys   Early car, late top, etc. What years are different...   Oct 28 2011, 09:22 AM
ppetion   IIRC it was changed in 73, so 70 -72 are the same ...   Oct 28 2011, 10:18 AM
andys   IIRC it was changed in 73, so 70 -72 are the same...   Oct 28 2011, 10:43 AM
ChrisNPDrider   Also these seals are much better with the flap, ...   Oct 28 2011, 02:18 PM
Philip W.   Also these seals are much better with the flap, ...   Oct 28 2011, 03:08 PM
PanelBilly   The problem is with the creamsickle and now its ou...   Oct 29 2011, 01:50 PM
ppetion   Now I have all my windows to align correctly, I wi...   Oct 30 2011, 10:59 AM
- Lo-Fi Version Time is now: 10th March 2026 - 12:09 PM
