> 1.8 with a D-Jet.... help. . . ., 1.8 lower, 1.7 top
broomhandle
post Oct 30 2011, 02:25 PM
So i have been driving this car for a year, last owner said it was a 1.7. it has all the 1.7 D-jet etc...
I should have done it before, but today messing with the FI, SN is EC012390....
74 1.8?
i went from 80 HP to 76HP in a second....
and now my question is.... will the D-jet setup even work with the 1.8?
i can see the fuel not getting enough.. etc.
any help?
broomhandle
post Oct 30 2011, 08:42 PM
It drops idle every second. its really under powered, backfires and that's about it.
i figured it was vacuum or fuel or both... i have rebuilt the injectors, all new fuel line. and vac hoses. points, time... no valves yet. that was next.
I just know the 1.8 has L-Jet and just thought.... crap. i wonder if this is all my problems.
the motor does have a pick/pull marking. so i have no idea about the motor.
and im in Fair Oaks, do you go to the donut rallys?
and, the whole car is odd, i find more and more.... tweakers with wheels should be illegal.
broomhandle   1.8 with a D-Jet.... help. . . .   Oct 30 2011, 02:25 PM
broomhandle   also, could i not have a bus motor? it runs like ...   Oct 30 2011, 02:58 PM
914Mike   also, could I not have a bus motor? ... any wise ...   Oct 30 2011, 11:30 PM
jimkelly   some pics pls. http://www.914world.com/specs/engn...   Oct 30 2011, 04:21 PM
broomhandle   some pics pls. http://www.914world.com/specs/eng...   Oct 30 2011, 06:45 PM
jcd914   1.8 is a low compression motor which means low vac...   Oct 30 2011, 07:59 PM
broomhandle   It drops idle every second. its really under power...   Oct 30 2011, 08:42 PM
vsg914   I've had a 1.8 with djet. No problems to speak...   Oct 31 2011, 06:17 AM
broomhandle   I've had a 1.8 with djet. No problems to spea...   Oct 31 2011, 12:52 PM
vsg914   Fuel dilivery system doesn't change cc's I...   Oct 31 2011, 01:03 PM
914Mels   Our '70 is a 1.7 converted to a 1.8 with the 9...   Oct 31 2011, 01:08 PM
vsg914   Our '70 is a 1.7 converted to a 1.8 with the ...   Oct 31 2011, 01:11 PM
914Mels   It's a Innovate mtx. It is all one piece, moun...   Oct 31 2011, 01:20 PM
broomhandle   It's a Innovate mtx. It is all one piece, mou...   Oct 31 2011, 02:09 PM
broomhandle   what is: dwell should be set prior to timing i...   Oct 31 2011, 01:43 PM
vsg914   what is: dwell should be set prior to timing ...   Oct 31 2011, 03:11 PM
Spoke   I'm running a 1.8L now with DJET from a 71. R...   Oct 31 2011, 02:13 PM
broomhandle   I'm running a 1.8L now with DJET from a 71. ...   Oct 31 2011, 02:47 PM
Spoke   your body work is great. What paint are you using...   Oct 31 2011, 07:16 PM
- Lo-Fi Version Time is now: 8th December 2025 - 11:02 AM
