> 1.8 with a D-Jet.... help. . . ., 1.8 lower, 1.7 top
broomhandle
post Oct 30 2011, 02:25 PM
So i have been driving this car for a year, last owner said it was a 1.7. it has all the 1.7 D-jet etc...
I should have done it before, but today messing with the FI, SN is EC012390....
74 1.8?
i went from 80 HP to 76HP in a second....
and now my question is.... will the D-jet setup even work with the 1.8?
i can see the fuel not getting enough.. etc.
any help?
Spoke
post Oct 31 2011, 02:13 PM
Jerry
I'm running a 1.8L now with DJET from a 71.
Runs very well. I don't have the rich state. Actually running a bit lean.
Check here for details:
Spoke's Project Thread
broomhandle
post Oct 31 2011, 02:47 PM
QUOTE(Spoke @ Oct 31 2011, 01:13 PM) *
awesome build. your red '71 makes my '71 project a dream... i thought i had bad rust... gives me hope, cool build....
i feel my 1.8 is running lean as well.... I will mess with it more....
your body work is great. What paint are you using? and are you doing a clear coat?
Spoke
post Oct 31 2011, 07:16 PM
Jerry
QUOTE(broomhandle @ Oct 31 2011, 04:47 PM) *
Thanks.
I'm using PPG paints in single stage. No clear coat. I'm painting only portions of the car as I repair the unending rust.
broomhandle   1.8 with a D-Jet.... help. . . .   Oct 30 2011, 02:25 PM
broomhandle   also, could i not have a bus motor? it runs like ...   Oct 30 2011, 02:58 PM
914Mike   also, could I not have a bus motor? ... any wise ...   Oct 30 2011, 11:30 PM
jimkelly   some pics pls. http://www.914world.com/specs/engn...   Oct 30 2011, 04:21 PM
broomhandle   some pics pls. http://www.914world.com/specs/eng...   Oct 30 2011, 06:45 PM
jcd914   1.8 is a low compression motor which means low vac...   Oct 30 2011, 07:59 PM
broomhandle   It drops idle every second. its really under power...   Oct 30 2011, 08:42 PM
vsg914   I've had a 1.8 with djet. No problems to speak...   Oct 31 2011, 06:17 AM
broomhandle   I've had a 1.8 with djet. No problems to spea...   Oct 31 2011, 12:52 PM
vsg914   Fuel dilivery system doesn't change cc's I...   Oct 31 2011, 01:03 PM
914Mels   Our '70 is a 1.7 converted to a 1.8 with the 9...   Oct 31 2011, 01:08 PM
vsg914   Our '70 is a 1.7 converted to a 1.8 with the ...   Oct 31 2011, 01:11 PM
914Mels   It's a Innovate mtx. It is all one piece, moun...   Oct 31 2011, 01:20 PM
broomhandle   It's a Innovate mtx. It is all one piece, mou...   Oct 31 2011, 02:09 PM
broomhandle   what is: dwell should be set prior to timing i...   Oct 31 2011, 01:43 PM
vsg914   what is: dwell should be set prior to timing ...   Oct 31 2011, 03:11 PM
Spoke   I'm running a 1.8L now with DJET from a 71. R...   Oct 31 2011, 02:13 PM
broomhandle   I'm running a 1.8L now with DJET from a 71. ...   Oct 31 2011, 02:47 PM
Spoke   your body work is great. What paint are you using...   Oct 31 2011, 07:16 PM
- Lo-Fi Version Time is now: 8th December 2025 - 11:02 AM
