good news!!, , and electrical questions |
tat2dphreak |
Apr 30 2004, 07:16 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
first the thrills of victory: the engine's in, and starts (IMG:style_emoticons/default/clap56.gif) it took a push button for the starter(temp fix) but the damn thing will run...
now the new barrage of questions: 1) when I turn the key "on" the brake lights in the rear come on... now, I don't have the front brakes even attached right now (SOON) but will that cause the brake lights to be on? what to check? (IMG:style_emoticons/default/confused24.gif) 2) this one is just annoying: when I turn on a blinker(either) they work fine on the outside of the car, just like they are supposed to, but both indicators on the tach come one (like when the hazards are on)... the hazard switch works perfect... I just don't get why both indicators come on (IMG:style_emoticons/default/headbang.gif) 3) there are 3-4 wires that the wiring diagram shows going to the coil... but which side? there's a green wire from the distro, a blk/red wire, a blk/purple wire and I think there's 1 more... but I could be wrong? at anyrate, which side (+or - ) do these wires go to on the coil? thanks in advance! |
tat2dphreak |
Apr 30 2004, 09:25 PM
QUOTE(Joe Ricard @ Apr 30 2004, 07:57 PM) Green wire from distributor is on Negative side. Pulling this out of my ass but one of the black wires has 12V on it and goes to the positive side. You also have the tach wire I believe negative side but you better check me on that. Geesh thats what I get for jumpin in and talking out my ass. Hope I haven't confused you more. actually I think you cleared everything up... the diagram shows the green wire and one other on one side, with the other wire on the opposite side... but the +/- is not labeled (IMG:style_emoticons/default/sad.gif) if the green/? is on neg. then the other wire is on pos. thanks!! I will check the other things tomm. |
Lo-Fi Version | Time is now: 11th June 2024 - 03:10 AM |
