Winter Heat, What's working for you? |
bandjoey |
Nov 9 2011, 06:27 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
It's finally getting below 50degrees here at night, and I'm looking for more garage heat. Standard 2 car garage with leaky overhead door....
Last year I had an oil radiator with blower and ceramic tower both with 1500 watts. They worked ok after a 30-45 minute warmup period. Looking at a 15,000 watt ceramic heater top that attaches to a propane large propane bottle (bbq grill size). Anyone use this and does it work? Other portable heaters that work? |
rick 918-S |
Nov 9 2011, 07:22 PM
Hey nice rack! -Celette Group: Members Posts: 20,473 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I've tried every kind of heater to find an affordable solution for my garage. I have tubing in the floor for a heated slab. Unfortunately the water heater I purchased (because I was told that would work awesome (IMG:style_emoticons/default/dry.gif) ) failed.
Then I moved to a propane unvented wall heater. That heated the garage nicely but stunk when you sprayed anything in the air. And the cost of propane sux. I put up with the propane company jacking me with the rates for three years. I purchased an electric boiler to heat the floor. As soon as I got my first bill I got a letter telling me because my garage has it's own meter and I am being charged a commercial rate I was now being placed on a commercial demand rate (IMG:style_emoticons/default/WTF.gif). The problem with heating the floor when your not working the the garage is it continues to cost money. If I had one residential meter the electric company would have had to supply all the power I wanted to use at a residential rate. After the first 500.00 bill Sandy was not amused (IMG:style_emoticons/default/slap.gif) So, I ran a gas line from the house to a unit heater. The cost is 1/10 of the cost of propane and I can shut it off when I'm not in the garage. Anyone want an electric hydronic boiler I have one in the classifieds. http://www.914world.com/bbs2/index.php?showtopic=153087 |
tadink |
Nov 10 2011, 12:14 AM
Member Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California |
I've tried every kind of heater to find an affordable solution for my garage. I have tubing in the floor for a heated slab. Unfortunately the water heater I purchased (because I was told that would work awesome (IMG:style_emoticons/default/dry.gif) ) failed. Then I moved to a propane unvented wall heater. That heated the garage nicely but stunk when you sprayed anything in the air. And the cost of propane sux. I put up with the propane company jacking me with the rates for three years. I purchased an electric boiler to heat the floor. As soon as I got my first bill I got a letter telling me because my garage has it's own meter and I am being charged a commercial rate I was now being placed on a commercial demand rate (IMG:style_emoticons/default/WTF.gif). The problem with heating the floor when your not working the the garage is it continues to cost money. If I had one residential meter the electric company would have had to supply all the power I wanted to use at a residential rate. After the first 500.00 bill Sandy was not amused (IMG:style_emoticons/default/slap.gif) So, I ran a gas line from the house to a unit heater. The cost is 1/10 of the cost of propane and I can shut it off when I'm not in the garage. Anyone want an electric hydronic boiler I have one in the classifieds. http://www.914world.com/bbs2/index.php?showtopic=153087 have you considered adding some solar collectors to your garage loop? even in the cold, if there is sunshine you'll have plenty of FREE heat.....contact me directly and I can point you in the right direction - td |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:20 AM |
