| andys |
Nov 11 2011, 10:42 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None
So if I replace my backpad with a carpeted one, what do you guys do if you have an access panel? If I glue down the carpet, should I perhaps cut a flap or? Any suggestions would be appreciated.
Thanks, Andys |
| Scott S |
Nov 11 2011, 11:34 AM
Small Member ![]() ![]() ![]() Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi Andys -
I just did this myself. My firewall has been carpeted for several years, so it was a pain in the butt to do the access panel (I had to remove the existing carpet). If yours has yet to be carpeted, it is very easy. Cut your hole in the car and build up your cover plate. Make sure the coverplate has at least 1" overlap all the way around. I drilled holes for the mounting screws in the plate, then held the plate up to the hole in the firewall and marked where to drill the firewall. There are a ton of different ways you can fasten it. I welded nuts over the holes on the engine side of the firewall - works like a champ. Then just upohlster everything up using 3M spray adhesive . On the cover plate, wrap it just enough around the edged to stay put. On the firewall, mount the carpet to everything first, then come back and trim. I left the edge of the carpet a half inch away from the acces panel opeing. My thinking was that this is still a firewall, and I want things sealed up tight (no carpet exposed to the engine compartment as any sort of "wick" to the interior). One thing to note - the rear interior firewall is one compound curve after another. If you think you can just cut square piece of carpet and glue it in, you will not be happy with the results. Get yourself a spray bottle of water and a heat gun or hair dryer. This will allow you stretch and mold the perlon to fit all of the ins and outs of the panel. it took me the better part of a day to get that carpet piece put in where I was happy with the results - and my hand/fingers were sore as hell afterwards. |
andys Carpeted Firewall Nov 11 2011, 10:42 AM
germanv82000
So if I replace my backpad with a carpeted one, w... Nov 11 2011, 11:00 AM
pcar916 Kinda depends on your access cover. I have mine (n... Nov 11 2011, 11:25 AM
Razorbobsr
Hi Andys -
I just did this myself. My firewall ha... Nov 14 2011, 11:34 AM
pcar916
Just what does the access panel allow you to get ... Nov 14 2011, 11:58 AM
rfuerst911sc When I go to do mine I plan on one piece of carpet... Nov 11 2011, 03:15 PM
andys Here's a photo of my access panel.
I'm th... Nov 13 2011, 10:51 AM
rohar Have you thought of cutting a piece of carpet to m... Nov 13 2011, 11:03 AM
andys
Have you thought of cutting a piece of carpet to ... Nov 14 2011, 10:46 AM
Vacca Rabite Bob,
If you have a 6, getting to the fan and pull... Nov 14 2011, 12:12 PM
Razorbobsr
Bob,
If you have a 6, getting to the fan and pul... Nov 15 2011, 10:30 AM
Razorbobsr
Bob,
If you have a 6, getting to the fan and pul... Nov 15 2011, 10:49 AM
Rod I don't understand why no-one has made a cover... Nov 14 2011, 02:37 PM
moparrob
I don't understand why no-one has made a cove... Nov 14 2011, 09:44 PM
nsr-jamie
I don't understand why no-one has made a cove... Nov 15 2011, 08:49 AM
computers4kids
So if I replace my backpad with a carpeted one, w... Nov 14 2011, 10:50 PM
andys
I know you're going with carpet, but it seem... Nov 15 2011, 09:21 AM
clow
I don't understand why no-one has made a cove... Nov 14 2011, 10:59 PM
pcar916 Gentlemen, it's a firewall. An acrylic cover i... Nov 15 2011, 09:11 AM
zymurgist
Gentlemen, it's a firewall. An acrylic cover ... Nov 15 2011, 10:28 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 12:07 AM |
