good news!!, , and electrical questions |
tat2dphreak |
Apr 30 2004, 07:16 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
first the thrills of victory: the engine's in, and starts (IMG:style_emoticons/default/clap56.gif) it took a push button for the starter(temp fix) but the damn thing will run...
now the new barrage of questions: 1) when I turn the key "on" the brake lights in the rear come on... now, I don't have the front brakes even attached right now (SOON) but will that cause the brake lights to be on? what to check? (IMG:style_emoticons/default/confused24.gif) 2) this one is just annoying: when I turn on a blinker(either) they work fine on the outside of the car, just like they are supposed to, but both indicators on the tach come one (like when the hazards are on)... the hazard switch works perfect... I just don't get why both indicators come on (IMG:style_emoticons/default/headbang.gif) 3) there are 3-4 wires that the wiring diagram shows going to the coil... but which side? there's a green wire from the distro, a blk/red wire, a blk/purple wire and I think there's 1 more... but I could be wrong? at anyrate, which side (+or - ) do these wires go to on the coil? thanks in advance! |
94teener |
May 2 2004, 12:19 AM
Member Group: Members Posts: 209 Joined: 6-February 04 From: Jacksonville, FL Member No.: 1,636 |
Andy,
Yes, you are correct about the 72 wiring, but where is the diode you mention? Burned out turn signal bulbs will also cause dimmed turn signal indicator lamps. If you have both turn signal bulbs burned out on the same side of the car, then your turn signal indicator lamp for the opposite side of the car will not illuminate at all. Phil |
Lo-Fi Version | Time is now: 11th June 2024 - 12:09 AM |
