| Krieger |
Nov 15 2011, 07:34 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,855 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Hot warm or nothing?
| GeorgeRud |
Nov 15 2011, 08:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I ran mine along the passenger side outside longitudinal using -12 braided line, and it was quite easy. That way you can still keep the heater tubes intact if you plan to run heat exchangers at some time.
Krieger How hot does your longitutinal get Nov 15 2011, 07:34 PM
Racing916 Not to bad, I have never noticed it, The hard part... Nov 15 2011, 07:37 PM
kg6dxn I'm running water lines for my heater in the l... Nov 15 2011, 07:51 PM
SirAndy If i had to do it again, i'd run them outside ... Nov 15 2011, 07:51 PM
kg6dxn
Whatever you do, don't run them on the inside... Nov 15 2011, 07:55 PM
larryM that's the way the euro racing GT's were d... Nov 16 2011, 12:36 PM
Krieger
If i had to do it again, Because if you do, your... Nov 15 2011, 08:47 PM
SirAndy :D You might have to do them again! Are you ... Nov 15 2011, 09:03 PM
Krieger Is it on your side or passenger? You took the duc... Nov 15 2011, 08:06 PM
kg6dxn I left the tube in place in the long. I removed th... Nov 15 2011, 08:11 PM
kg6dxn
I left the tube in place in the long. I removed t... Nov 15 2011, 08:13 PM
Krieger Andy, I'm not sure of your future routing you ... Nov 15 2011, 09:06 PM
Andy, I'm not sure of your future routing you... Nov 15 2011, 10:03 PM
Krieger I see now. I like that idea. Were you going to m... Nov 15 2011, 11:20 PM
Krieger
What if you ran them inside the fenderwell, then... Nov 15 2011, 11:31 PM
moparrob I like that idea. I need to run mine as well and ... Nov 15 2011, 11:41 PM
rwilner PO ran hoses to my front mounted oil cooler throug... Nov 16 2011, 06:39 AM
pcar916 I ran my -12AN lines through the passenger-side he... Nov 16 2011, 08:05 AM
yeahmag What is the "Parker" hose you are using ... Nov 16 2011, 12:57 PM
What is the "Parker" hose you are using... Nov 16 2011, 01:13 PM
dion9146
What is the "Parker" hose you are usin... Dec 9 2011, 07:11 AM
BKLA Mr. Shea has some really cool, solid lines that ru... Nov 16 2011, 02:17 PM
GeorgeRud Parker is a large manufacturer of hydraulic hoses ... Dec 9 2011, 10:23 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 06:16 PM |
