| Krieger |
Nov 15 2011, 07:34 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,855 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Hot warm or nothing?
| Krieger |
Nov 15 2011, 09:06 PM
Andy, I'm not sure of your future routing you described. Would they go into the front fender? Is that where you'd build a box?
Krieger How hot does your longitutinal get Nov 15 2011, 07:34 PM
Racing916 Not to bad, I have never noticed it, The hard part... Nov 15 2011, 07:37 PM
kg6dxn I'm running water lines for my heater in the l... Nov 15 2011, 07:51 PM
SirAndy If i had to do it again, i'd run them outside ... Nov 15 2011, 07:51 PM
kg6dxn
Whatever you do, don't run them on the inside... Nov 15 2011, 07:55 PM
larryM that's the way the euro racing GT's were d... Nov 16 2011, 12:36 PM
Krieger
If i had to do it again, Because if you do, your... Nov 15 2011, 08:47 PM
SirAndy :D You might have to do them again! Are you ... Nov 15 2011, 09:03 PM
Krieger Is it on your side or passenger? You took the duc... Nov 15 2011, 08:06 PM
kg6dxn I left the tube in place in the long. I removed th... Nov 15 2011, 08:11 PM
kg6dxn
I left the tube in place in the long. I removed t... Nov 15 2011, 08:13 PM
GeorgeRud I ran mine along the passenger side outside longit... Nov 15 2011, 08:13 PM
Andy, I'm not sure of your future routing you... Nov 15 2011, 10:03 PM
Krieger I see now. I like that idea. Were you going to m... Nov 15 2011, 11:20 PM
Krieger
What if you ran them inside the fenderwell, then... Nov 15 2011, 11:31 PM
moparrob I like that idea. I need to run mine as well and ... Nov 15 2011, 11:41 PM
rwilner PO ran hoses to my front mounted oil cooler throug... Nov 16 2011, 06:39 AM
pcar916 I ran my -12AN lines through the passenger-side he... Nov 16 2011, 08:05 AM
yeahmag What is the "Parker" hose you are using ... Nov 16 2011, 12:57 PM
What is the "Parker" hose you are using... Nov 16 2011, 01:13 PM
dion9146
What is the "Parker" hose you are usin... Dec 9 2011, 07:11 AM
BKLA Mr. Shea has some really cool, solid lines that ru... Nov 16 2011, 02:17 PM
GeorgeRud Parker is a large manufacturer of hydraulic hoses ... Dec 9 2011, 10:23 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 06:16 PM |
