> How hot does your longitutinal get, considering running oil lines inside long for a six
Krieger
post Nov 15 2011, 07:34 PM
Hot warm or nothing?
post Nov 15 2011, 07:51 PM
Resident German
If i had to do it again, i'd run them outside and cut through the front portion of the long (make a nice box) and run them through the channel under the gas tank.
That way, you can keep the heater mufflers if you ever need them plus the oil gets more cooling running on the outside.
Whatever you do, don't run them on the inside. Because if you do, your GF will kill you after your first roadtrip.
Mike Bellis
post Nov 15 2011, 07:55 PM
Resident Electrician
QUOTE(SirAndy @ Nov 15 2011, 06:51 PM) *
(IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif)
I ran my oil cooler lines under my outer rocker panel. I have a hole in the lower left side firewall, in the front they go through the existing opening in the front fender well.
larryM
post Nov 16 2011, 12:36 PM
emoze
that's the way the euro racing GT's were done
a crude "cover" was used over the lines where they went thru, under where you probably now have your footrest
and NO - they don't get hot enuf to notice - but if you used copper water pipes (not soft tubing) intsead of rubber you would have the equivalent of a 911 trombone oil cooler
theoretically you could hook em up to a "heater core" instead of the front cooler
the VW bug guys have had a kit to feed copper oil lines into the longitudinal heater duct for many years - it is not a new idea
QUOTE(kg6dxn @ Nov 15 2011, 05:55 PM) *
Krieger   How hot does your longitutinal get   Nov 15 2011, 07:34 PM
Racing916   Not to bad, I have never noticed it, The hard part...   Nov 15 2011, 07:37 PM
kg6dxn   I'm running water lines for my heater in the l...   Nov 15 2011, 07:51 PM
SirAndy   If i had to do it again, i'd run them outside ...   Nov 15 2011, 07:51 PM
kg6dxn   Whatever you do, don't run them on the inside...   Nov 15 2011, 07:55 PM
larryM   that's the way the euro racing GT's were d...   Nov 16 2011, 12:36 PM
Krieger   If i had to do it again, Because if you do, your...   Nov 15 2011, 08:47 PM
SirAndy   :D You might have to do them again! Are you ...   Nov 15 2011, 09:03 PM
Krieger   Is it on your side or passenger? You took the duc...   Nov 15 2011, 08:06 PM
kg6dxn   I left the tube in place in the long. I removed th...   Nov 15 2011, 08:11 PM
kg6dxn   I left the tube in place in the long. I removed t...   Nov 15 2011, 08:13 PM
GeorgeRud   I ran mine along the passenger side outside longit...   Nov 15 2011, 08:13 PM
Krieger   Andy, I'm not sure of your future routing you ...   Nov 15 2011, 09:06 PM
SirAndy   Andy, I'm not sure of your future routing you...   Nov 15 2011, 10:03 PM
Krieger   I see now. I like that idea. Were you going to m...   Nov 15 2011, 11:20 PM
Krieger   What if you ran them inside the fenderwell, then...   Nov 15 2011, 11:31 PM
moparrob   I like that idea. I need to run mine as well and ...   Nov 15 2011, 11:41 PM
rwilner   PO ran hoses to my front mounted oil cooler throug...   Nov 16 2011, 06:39 AM
pcar916   I ran my -12AN lines through the passenger-side he...   Nov 16 2011, 08:05 AM
yeahmag   What is the "Parker" hose you are using ...   Nov 16 2011, 12:57 PM
SirAndy   What is the "Parker" hose you are using...   Nov 16 2011, 01:13 PM
dion9146   What is the "Parker" hose you are usin...   Dec 9 2011, 07:11 AM
BKLA   Mr. Shea has some really cool, solid lines that ru...   Nov 16 2011, 02:17 PM
GeorgeRud   Parker is a large manufacturer of hydraulic hoses ...   Dec 9 2011, 10:23 AM
- Lo-Fi Version Time is now: 1st May 2026 - 06:14 PM
