> weltmeister springs - which do you suggest., how much difference is there between #100 & #140's?
DRPHIL914
post Jul 19 2011, 10:26 PM
Dr. Phil
I have a 75 2.0, with 8spoke empi 15" 4 lug, and 195/55 performance tires. Currently have bilistein sport shocks, adjustable with newer #100 springs. When set higher to give better clearance its pretty bouncy, so I moved them down 3 notches to take tension off springs but before I rolled the fender lips they would have almost zero clearance on outside.
Would going to #140s help. I know there is an inch diff in height so if I put the shock setting higher- more pressure on the spring I will get a little higher ride, but will it be too stiff for daily driving and the occasional d.e. on the road course- robeling road? It should bounce less but .
Anyone used this combination? I've not had the #140s but have a chance to buy some.
Need some I.put to make a decision on this.
Thanks
Phil
I also have stock sway bar with new bushings
stugray
post Nov 16 2011, 05:46 PM
"Are you running a rear bar? LSD? Shocks? Stock rubber or delrin?"
22mm Welt front sway bar, no LSD (yet)
23mmm hollow torsion bars
Front shocks have not been upgraded as far as I know ( need to look & upgrade to match the rears).
Stock rubber for now.
I am tending to say that the 300lbs suggested by the vendor is right.
Stu
Philip W.   weltmeister springs - which do you suggest.   Jul 19 2011, 10:26 PM
Dr Evil   140 ;)   Jul 19 2011, 10:45 PM
Philip W.   140 ;) O.k so my stupid phone posted this twice...   Jul 19 2011, 10:54 PM
kg6dxn   That's not funny! :(   Jul 19 2011, 10:47 PM
SUNAB914   I believe 140's will make it lower.   Jul 20 2011, 06:55 AM
sean_v8_914   springs and dampers should be better matched. whil...   Jul 20 2011, 07:16 AM
Philip W.   springs and dampers should be better matched. whi...   Jul 20 2011, 07:38 AM
pcar916   I'd go for the 140's in a heartbeat. They...   Jul 20 2011, 07:59 AM
Cupomeat   Hey, I thought that Bilstein shocks are not adjust...   Jul 20 2011, 08:26 AM
Philip W.   I have sway bar with new bushings, the shocks are...   Jul 20 2011, 10:09 AM
Cupomeat   I have sway bar with new bushings, the shocks ar...   Jul 20 2011, 05:03 PM
Vacca Rabite   I have weltmiester 140s on my car with nonadjustab...   Jul 20 2011, 08:45 AM
Vacca Rabite   Also, with 140s you can use stock front A arms bu...   Jul 20 2011, 08:48 AM
eric9144   I have 140# springs on red Koni adjustables, stock...   Jul 20 2011, 11:15 AM
eric9144   Edit: duplicate post :)   Jul 20 2011, 11:16 AM
Philip W.   I have 140# springs on red Koni adjustables, stoc...   Jul 20 2011, 12:32 PM
draganc   I have 140# springs on red Koni adjustables, sto...   Nov 16 2011, 08:42 PM
Philip W.   [quote name='Philip W.' post='1512059' date='Jul ...   Nov 17 2011, 09:02 AM
eric9144   With my perches set to the lowest position my ride...   Jul 20 2011, 02:17 PM
stugray   HELP! I am about to buy the Ground Control coi...   Nov 16 2011, 01:51 PM
DanT   HELP! I am about to buy the Ground Control co...   Nov 16 2011, 03:47 PM
yeahmag   I disagree. I have 21mm torsion bars and have gone...   Nov 16 2011, 03:56 PM
DanT   IIRC hollow 23mm bars are the equivalent spring ra...   Nov 16 2011, 04:45 PM
yeahmag   Were you running Hoosiers? Things changed quickly ...   Nov 16 2011, 05:03 PM
DanT   Were you running Hoosiers? Things changed quickly...   Nov 16 2011, 05:05 PM
stugray   "Are you running a rear bar? LSD? Shocks? Sto...   Nov 16 2011, 05:46 PM
yeahmag   The stock rubber adds perceived spring rate as it ...   Nov 16 2011, 05:48 PM
majkos   :agree: doesn't look correct.   Nov 17 2011, 09:00 AM
- Lo-Fi Version Time is now: 8th December 2025 - 06:31 PM
