> Fuch Valve Stems, Are there special ones out there ?
913B
post Nov 15 2011, 11:33 PM
So the local tire shop mounting my recent re-finished 14x5.5 Fuchs does not have the right vavle stem, luckily the owner checked on the installer's work and notice the the regular valve sem was not seated properly. So is there special valve stems for the 14" of Fuchs in general, or is it that the tire shop was not adequately supplied with the valve stems ??
I can see where the hole where the valve stem seats is especially thicker than the typical wheel. I should have taken a picture.
Anyone have any been there done that before comments ???
Thanks in advance
Ted
913B
post Nov 16 2011, 06:52 PM
So what I read on pelican I need the TR415 stem. I tried the threaded metal version since it had the same diameter but it was not long enough going thru the wheel.
I'm going to have the tire shop try the rubber one tomorrow and let you'all know.
FYI, the regular valve stems do not fit.
- Lo-Fi Version Time is now: 12th June 2026 - 12:38 PM
