| DRPHIL914 |
Jul 19 2011, 10:26 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,874 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States
I have a 75 2.0, with 8spoke empi 15" 4 lug, and 195/55 performance tires. Currently have bilistein sport shocks, adjustable with newer #100 springs. When set higher to give better clearance its pretty bouncy, so I moved them down 3 notches to take tension off springs but before I rolled the fender lips they would have almost zero clearance on outside.
Would going to #140s help. I know there is an inch diff in height so if I put the shock setting higher- more pressure on the spring I will get a little higher ride, but will it be too stiff for daily driving and the occasional d.e. on the road course- robeling road? It should bounce less but . Anyone used this combination? I've not had the #140s but have a chance to buy some. Need some I.put to make a decision on this. Thanks Phil I also have stock sway bar with new bushings |
| eric9144 |
Jul 20 2011, 11:16 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,783 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California
Edit: duplicate post (IMG:style_emoticons/default/smile.gif)
| DRPHIL914 |
Jul 20 2011, 12:32 PM
I have 140# springs on red Koni adjustables, stock torsion bars, the big weltmeister front sway bar, 205/60's on 2.0 Fuchs, it's been a fantastic combo for street, AX, DE...the Konis had the 3 position perch in back to adjust ride height so sorting that out was easy. Do it... Snubbers are the rubber stops that prevent metal bashing should you "bottom out" your suspension on a hard bump this was taken before i put the new sway bar bushings in but you can see the slots for changing the silver spring plate location, up on down. Attached image(s)
| draganc |
Nov 16 2011, 08:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
I have 140# springs on red Koni adjustables, stock torsion bars, the big weltmeister front sway bar, 205/60's on 2.0 Fuchs, it's been a fantastic combo for street, AX, DE...the Konis had the 3 position perch in back to adjust ride height so sorting that out was easy. Do it... Snubbers are the rubber stops that prevent metal bashing should you "bottom out" your suspension on a hard bump this was taken before i put the new sway bar bushings in but you can see the slots for changing the silver spring plate location, up on down. I don;t know if 'm late with my post, but I think your rear sway bar is mounted "backwards". it needs to point to the front and up. |
| DRPHIL914 |
Nov 17 2011, 09:02 AM
I have 140# springs on red Koni adjustables, stock torsion bars, the big weltmeister front sway bar, 205/60's on 2.0 Fuchs, it's been a fantastic combo for street, AX, DE...the Konis had the 3 position perch in back to adjust ride height so sorting that out was easy. Do it... Snubbers are the rubber stops that prevent metal bashing should you "bottom out" your suspension on a hard bump this was taken before i put the new sway bar bushings in but you can see the slots for changing the silver spring plate location, up on down. I don;t know if 'm late with my post, but I think your rear sway bar is mounted "backwards". it needs to point to the front and up. yes,- they were not really attached in that picture. i had just put the new shocks and springs in and in the process of pulling the pin out, the bushings just crumbled!, I now have new bushings installed- in the correct position (IMG:style_emoticons/default/rolleyes.gif) by the way, just doing some fun local road street driving, i am amazed at how this car corners with the current set up ( (IMG:style_emoticons/default/smile.gif) ) of Stock front and rear sway bars, rear welt.100# springs with the bilistein sport shocks. I really want to get a chance at putting it on an AX course (stock front inserts i think). (IMG:style_emoticons/default/biggrin.gif) I believe i will leave it alone right now , because it s plenty stiff right now, has good balance so, any other change would not be necessary i do not believe. |
Philip W. weltmeister springs - which do you suggest. Jul 19 2011, 10:26 PM
Dr Evil 140 ;) Jul 19 2011, 10:45 PM
Philip W.
140 ;)
O.k so my stupid phone posted this twice... Jul 19 2011, 10:54 PM
kg6dxn That's not funny! :( Jul 19 2011, 10:47 PM
SUNAB914 I believe 140's will make it lower. Jul 20 2011, 06:55 AM
sean_v8_914 springs and dampers should be better matched. whil... Jul 20 2011, 07:16 AM
Philip W.
springs and dampers should be better matched. whi... Jul 20 2011, 07:38 AM
pcar916 I'd go for the 140's in a heartbeat.
They... Jul 20 2011, 07:59 AM
Cupomeat Hey, I thought that Bilstein shocks are not adjust... Jul 20 2011, 08:26 AM
Philip W. I have sway bar with new bushings,
the shocks are... Jul 20 2011, 10:09 AM
Cupomeat
the shocks ar... Jul 20 2011, 05:03 PM
Vacca Rabite I have weltmiester 140s on my car with nonadjustab... Jul 20 2011, 08:45 AM
Vacca Rabite Also, with 140s you can use stock front A arms bu... Jul 20 2011, 08:48 AM
eric9144 I have 140# springs on red Koni adjustables, stock... Jul 20 2011, 11:15 AM
eric9144 With my perches set to the lowest position my ride... Jul 20 2011, 02:17 PM
stugray HELP! I am about to buy the Ground Control coi... Nov 16 2011, 01:51 PM
DanT
HELP! I am about to buy the Ground Control co... Nov 16 2011, 03:47 PM
yeahmag I disagree. I have 21mm torsion bars and have gone... Nov 16 2011, 03:56 PM
DanT IIRC hollow 23mm bars are the equivalent spring ra... Nov 16 2011, 04:45 PM
yeahmag Were you running Hoosiers? Things changed quickly ... Nov 16 2011, 05:03 PM
DanT
Were you running Hoosiers? Things changed quickly... Nov 16 2011, 05:05 PM
stugray "Are you running a rear bar? LSD? Shocks? Sto... Nov 16 2011, 05:46 PM
yeahmag The stock rubber adds perceived spring rate as it ... Nov 16 2011, 05:48 PM
majkos :agree: doesn't look correct. Nov 17 2011, 09:00 AM![]() ![]() |
Lo-Fi Version | Time is now: 8th December 2025 - 06:27 PM |
