> To Washer or not to Washer, That is bolt the question
ezbngreen914
post Nov 20 2011, 03:25 PM
I'm replacing the oil pressure sending unit on my 1.7. There was no washer when I took the old unit out but I suspect that the unit was leaking and can't rule out that it should not have had a washer. AAs parts pdf shows a washer for the Temp sending unit option but its hard to tell whether it means for there to be one on the standard unit that I am using as well. The guy from AA sent me the washer just incase. The Haynes manual doesn't mention a washer but I'm just looking for some good old 914 World feed back, Nothing beats it!
Question: Should I use the metal washer or not?
Thanks again! (IMG:style_emoticons/default/beerchug.gif)
yeahmag
post Nov 20 2011, 03:51 PM
Just to be sure I read this right - you are talking about the oil PRESSURE unit on top of the motor. That uses no washer and is just "snug". It's a tapered thread like NPT.
The oil temp senders in the taco plate uses a copper crush washer.
-Aaron
- Lo-Fi Version Time is now: 30th September 2026 - 01:21 AM
