> To Washer or not to Washer, That is bolt the question
ezbngreen914
post Nov 20 2011, 03:25 PM
I'm replacing the oil pressure sending unit on my 1.7. There was no washer when I took the old unit out but I suspect that the unit was leaking and can't rule out that it should not have had a washer. AAs parts pdf shows a washer for the Temp sending unit option but its hard to tell whether it means for there to be one on the standard unit that I am using as well. The guy from AA sent me the washer just incase. The Haynes manual doesn't mention a washer but I'm just looking for some good old 914 World feed back, Nothing beats it!
Question: Should I use the metal washer or not?
Thanks again! (IMG:style_emoticons/default/beerchug.gif)
type47
post Nov 21 2011, 08:37 AM
Viermeister
No washer for pressure sensor to case. If you decide to use teflon tape, be sure to allow the sensor to ground to the case (don't insulate by using tape) and don't let tape get into oil passages.
- Lo-Fi Version Time is now: 30th September 2026 - 01:21 AM
