| kbrunk1 |
Nov 21 2011, 08:49 PM
Brunk ![]() ![]() Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
(IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) Just getting started bringing back a 73 2.0 Should I rebuild the master brake cylinder and brakes even if they seem to work?
Also need advice on how to get tar out of gas lines and injectors? |
| McMark |
Nov 21 2011, 10:03 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Safety first. Get good brakes on there. Pretty much every revived 914 that I run across has sticky calipers, and often have leaky master cylinders. If you're putting it into regular service, I would install a new 19mm master cylinder (just because it's cheaper than the stock 17mm), new rubber lines, and get rebuilt calipers from PMB.
If there is crap in the fuel system, it also should be thoroughly cleaned. Otherwise you put the engine at risk of damage. Remove the tank and at least clean it out, replace all the fuel lines, and spray cleaner and air down the lines in the center tunnel. |
kbrunk1 Bringing Back to Life 73 914 Nov 21 2011, 08:49 PM
RobW
Safety first. Get good brakes on there. Pretty ... Nov 22 2011, 07:11 AM
76-914 Tar??????????? Nov 22 2011, 09:47 AM
swl
Tar???????????
yup. happens when old gas evapor... Nov 24 2011, 10:05 PM
kbrunk1 Should the tank be acid washed and or recoated or ... Nov 23 2011, 09:41 PM
McMark Pull the tank, remove the sender, filler neck, and... Nov 25 2011, 02:21 AM
kbrunk1 How do you test the spray pattern of the injectors... Dec 1 2011, 10:34 PM
SLITS
How do you test the spray pattern of the injector... Dec 2 2011, 08:12 AM
rick 918-S I just cleaned out a tank. I wasn't sure it wa... Dec 2 2011, 08:32 AM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 05:29 PM |
