A question for the slalom racers, Why is front-end so stiff you lift a wheel |
stewteral |
Nov 20 2011, 01:38 PM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
Hey Slalom Guys,
I've been bothered by the pics of your cars lifting the inside front wheel under cornering. Years ago, this was the set up for 911's to adjust away from the car's oversteering nature. However, from my past experience I've found that a car that would be too oversteery for the track would be about right for slaloms. As I saw it, it was most important to get the front end to turn-in crisply to carve the very tight turns. So what don't I understand about running 914's? Are your courses so fast now the a loose car will get away from you? The fastest course I ever ran just barely got Dad's old Cobra into 2nd gear (80 MPH). Best, Terry |
ChrisFoley |
Nov 22 2011, 01:37 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Its not just autocross 914s that pick up a front wheel while cornering. (IMG:style_emoticons/default/biggrin.gif)
I had outbraked the zee going into Big Bend. The picture was taken as I turned toward the 2nd apex. Speed - about 75mph. |
Randal |
Nov 22 2011, 01:57 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Its not just autocross 914s that pick up a front wheel while cornering. (IMG:style_emoticons/default/biggrin.gif) I had outbraked the zee going into Big Bend. The picture was taken as I turned toward the 2nd apex. Speed - about 75mph. OK we are impressed, your car is just stuck to to that corner. You must know someone that builds good suspension components! What tires you running? |
Lo-Fi Version | Time is now: 8th June 2024 - 07:54 PM |
