Tail shift Cable-shifter, Starting the finishing touches (With Video!) |
kevin311 |
Nov 2 2011, 10:26 AM
Member Group: Members Posts: 105 Joined: 22-May 10 From: Tampa Bay Area Member No.: 11,752 Region Association: None |
My Dad and I thought it would be a fun project to try and build a Cable shifter for my teener.
I can drive the car just fine with the regular shifter but he absolutely hates it. I cant really blame him, even after new bushings and adjustment its like playing with a stick in a sand bucket. I have seen the set-up that is on http://www.etischer.com/914cableshift.html but figured i could simplify it a bit. Heres what we have so far (please excuse the factory rustproofing (oil) still chasing leaks) and remember its still in mock up phase.. so things like where the cables attach to the transmission will be reinforced in the end. i will post more when its finished and cleaned up. (IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1320251207.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1320251208.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1320251208.3.jpg) Pics of the shifter i used (3000gt) and new shift knob (3 for $5 on ebay (IMG:style_emoticons/default/biggrin.gif) ) The cables aren't attached yet but this is pretty much where it will be positioned in the car. Most of the base plate will be cut off also to clean it up. (IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1320251208.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1320251209.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1320251209.6.jpg) This will all be hidden under the center cushion(sp?) in the last pic that i will build a new base for. So far I'm about $110 into this project 8' marine Teleflex cable $30 6' Teleflex cable $27 Rod ends $25 Shifter $15 (pick and pull) misc. (bolts, clips etc.) $10 Any comments or criticism are welcome! (IMG:style_emoticons/default/poke.gif) |
andys |
Nov 22 2011, 03:32 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
The mechanical look seems appealing enough; probably could leave it like it is. A boot would take some thought, as you'd have to devise a way to cover the whole assembly to look decent. You might also think about patterning out your own boot, and get someone to sew it for you. I'll probably go that wat on mine.
How's the location of the shifter work for you? I ask because it seems to be quite a bit back in relation to the original shifter position. Andys |
Lo-Fi Version | Time is now: 7th June 2024 - 08:25 PM |
