Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
For sale is a pair of rare 914-6 calipers completely restored to their preeminent glory.
For those looking these days, it was probably six months before I stumbled upon these. They have become rarer than hens teeth as of late. What you get with a 914-6 caliper is: * A slightly larger caliper that bolts on to any standard 914 rear arm. * A larger 911 rear pad size. * A pair of larger 38mm pistons (again, same as the 911 rear through 1983). * A caliper that will allow you to run a larger front caliper and retain proper brake bias. * A caliper that can easily be spaced to become the uber, uber rare 914-6/GT caliper... all with factory parts (inquire within). * A caliper that uses stock handbrake cables. * A true solution for those who want a little more brake in their 914. As mentioned above, these have become quite rare lately. Part of the reason is the Ferrari rear caliper market has gone through the roof as well, dragging this caliper along with it. If you've been wanting a pair for your project or, or your original 6 calipers have gone missing... these are for you. Asking $1,595.00 plus $10.50 shipping to U.S. destinations. $26.55 shipping to Canad and Mexico. $43.23 to Europe and Asia. ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Eric_Shea |
QUOTE worth anything? Not really... QUOTE What do you mean by "not good" for the early calipers? As Stu mentions above... it messes with your bias. 911's didn't have the 42mm piston in the rear until 1984 and that was the first 911 ever to have a pressure regulator to prevent rear lock up. For a 914 with stock brakes 42mm front and 33mm rear makes the most sense. If you want them to be better, get really good pads and bed them properly. For a 914-6 or a modified brake system stick with 48mm front and 38mm rear or, in the case of 951 calipers etc., go with the complete system that Porsche developed and work on a handbrake solution. That said, Stu's solution (aside from finding 914-6 rear calipers) is to get a 911 rear caliper and remove the spacer (or use with the spacer and go vented rotors). The 911 rear calipers are cast off the same mold as those (early 914 fronts) but they have the proper 38mm pistons. Vented rotors add weight were they are not needed in 99% of the cases. |
Lo-Fi Version | Time is now: 14th July 2025 - 10:13 AM |
