| EdwardBlume |
Nov 25 2011, 06:22 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
I broke the seal from the crank and it broke everything loose except the dowel underneath the oil cooler on the lower side of the engine.
How do I pull this area apart? |
| bigkensteele |
Nov 25 2011, 07:29 PM
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,200 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States
Isn't there one around the oil filler console that is easy to miss? Might be inside...
| EdwardBlume |
Nov 25 2011, 07:35 PM
Isn't there one around the oil filler console that is easy to miss? Might be inside... Thanks. Both 10MM nuts are off around the oil filler rectangle. Like I said, everything is free with 1-3 mm of free play less this one 4-6 inch elbow. I need a strong but gentle man to pull from the other side... |
RobW Splitting the Case Nov 25 2011, 06:22 PM
Vacca Rabite Find the bolt you missed.
Zach Nov 25 2011, 06:48 PM
RobW Didn't miss any.... unless there's one ins... Nov 25 2011, 07:06 PM
RobW Here's a bloody pict.... Nov 25 2011, 07:16 PM
RobW Everything is free except the 90 deg underneath th... Nov 25 2011, 07:18 PM
Van Probably dealing with some corrosion on a dowel pi... Nov 25 2011, 07:58 PM
a914dude Count yer nutz. <_< Nov 25 2011, 08:06 PM
RobW
Count yer nutz. <_<
"testes.. one,... Nov 25 2011, 08:20 PM
RobW LwIMsriGCd4 Nov 25 2011, 08:33 PM
Randal
LwIMsriGCd4
Nice video Rob. You just need to ... Nov 26 2011, 10:55 AM
Mark Henry Is there still a couple of washers on the studs? T... Nov 26 2011, 08:46 AM
jsconst It could be sealant holding it together there, I h... Nov 26 2011, 09:18 AM
RobW Got it.
I carefully took a straight edge piece o... Nov 26 2011, 09:34 AM
Jake Raby After watching the video I'll say that you jus... Nov 26 2011, 03:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 06:08 PM |
