> electronic ignition, name the components necessary
OKCSwope
post Nov 25 2011, 09:33 PM
I'm having a hard time sorting through all the possibilities out there. I want to do a pointless ignition. Can you recommend a list of components and prices?
hydroliftin
post Nov 25 2011, 09:54 PM
QUOTE(OKCSwope @ Nov 25 2011, 07:33 PM) *
It depends on what you are trying to accomplish. Is the engine a stock FI motor? Does it have carbs? What engine mods have you done or plan to do? What is your budget
OKCSwope
post Nov 25 2011, 10:25 PM
I'm running a 2.2 dual webers 4 cyl and my goal is to have a great street driveable autocrosser that I can tow to Hallet, Texas Motor Speedway, etc.
Sounds like Petronics and compu-fire are the best bets. Are those all-in-one kits? Do I still need a msd or coil?
OKCSwope   electronic ignition   Nov 25 2011, 09:33 PM
rnellums   I used Pertronix on one of mine. Uses a hall sens...   Nov 25 2011, 09:49 PM
OKCSwope   I used Pertronix on one of mine. Uses a hall sen...   Nov 26 2011, 12:04 AM
kg6dxn   I used Pertronix on one of mine. Uses a hall se...   Nov 26 2011, 12:17 AM
hydroliftin   I'm having a hard time sorting through all th...   Nov 25 2011, 09:54 PM
OKCSwope   I'm running a 2.2 dual webers 4 cyl and my goa...   Nov 25 2011, 10:25 PM
Mark Henry   Sounds like Petronics and compu-fire are the best...   Nov 26 2011, 08:43 AM
bigkensteele   I just installed a Pertronix a few weeks ago, and ...   Nov 25 2011, 09:55 PM
Cap'n Krusty   I'm having a hard time sorting through all th...   Nov 25 2011, 10:06 PM
jaxdream   I'm having a hard time sorting through all t...   Nov 26 2011, 08:03 AM
underthetire   Compu fire. Cleaner signal at lower rpm IMO. Both...   Nov 25 2011, 10:51 PM
Socalandy   I want to see more pics of the car in your avitar....   Nov 26 2011, 12:25 AM
rnellums   I believe I got the II, there was no rev limit adj...   Nov 26 2011, 12:34 AM
Spoke   I used this Pertronix module from Pelican. These a...   Nov 26 2011, 06:21 AM
76-914   IIRC, there is curreently only one Petronix model ...   Nov 26 2011, 09:39 AM
struckn   IIRC, there is curreently only one Petronix model...   Nov 29 2011, 03:47 PM
davidj   I was looking into this setup: Boost :beer2:   Nov 29 2011, 11:14 PM
Marty Yeoman   I run a MSD 6AL with a Bosch Blue coil, stock Bosc...   Nov 30 2011, 02:41 PM
struckn   I run a MSD 6AL with a Bosch Blue coil, stock Bos...   Nov 30 2011, 08:33 PM
aharder   I'm running a Crane Cams FireBall XR2000, Stoc...   Nov 30 2011, 10:33 PM
- Lo-Fi Version Time is now: 17th September 2026 - 03:25 PM
