| OKCSwope |
Nov 25 2011, 09:33 PM
Newbie ![]() Group: Members Posts: 3 Joined: 19-January 11 From: Oklahoma City Member No.: 12,614 Region Association: Southwest Region |
I'm having a hard time sorting through all the possibilities out there. I want to do a pointless ignition. Can you recommend a list of components and prices?
| rnellums |
Nov 25 2011, 09:49 PM
Professional Enthusiast ![]() ![]() ![]() Group: Members Posts: 1,673 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I used Pertronix on one of mine. Uses a hall sensor to sense timing and comes in at around 80 bucks. Some have had problems with them burning up if the ignition is on and the engine isn't running for a while.
Oh and I used it on a stock 2.0L with dual Webers. |
| OKCSwope |
Nov 26 2011, 12:04 AM
I used Pertronix on one of mine. Uses a hall sensor to sense timing and comes in at around 80 bucks. Some have had problems with them burning up if the ignition is on and the engine isn't running for a while. Oh and I used it on a stock 2.0L with dual Webers. I'm leaning towards the Petronix. Did you get the I, II or III? With the III, I could set my own rev limit. What kind of performance did you get? |
| Mike Bellis |
Nov 26 2011, 12:17 AM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
I used Pertronix on one of mine. Uses a hall sensor to sense timing and comes in at around 80 bucks. Some have had problems with them burning up if the ignition is on and the engine isn't running for a while. Oh and I used it on a stock 2.0L with dual Webers. I'm leaning towards the Petronix. Did you get the I, II or III? With the III, I could set my own rev limit. What kind of performance did you get? I want to see more pics of the car in your avitar. Please post! |
OKCSwope electronic ignition Nov 25 2011, 09:33 PM
hydroliftin
I'm having a hard time sorting through all th... Nov 25 2011, 09:54 PM
OKCSwope I'm running a 2.2 dual webers 4 cyl and my goa... Nov 25 2011, 10:25 PM
Mark Henry
Sounds like Petronics and compu-fire are the best... Nov 26 2011, 08:43 AM
bigkensteele I just installed a Pertronix a few weeks ago, and ... Nov 25 2011, 09:55 PM
Cap'n Krusty
I'm having a hard time sorting through all th... Nov 25 2011, 10:06 PM
jaxdream
I'm having a hard time sorting through all t... Nov 26 2011, 08:03 AM
underthetire Compu fire. Cleaner signal at lower rpm IMO.
Both... Nov 25 2011, 10:51 PM
Socalandy I want to see more pics of the car in your avitar.... Nov 26 2011, 12:25 AM
rnellums I believe I got the II, there was no rev limit adj... Nov 26 2011, 12:34 AM
Spoke I used this Pertronix module from Pelican. These a... Nov 26 2011, 06:21 AM
76-914 IIRC, there is curreently only one Petronix model ... Nov 26 2011, 09:39 AM
struckn
IIRC, there is curreently only one Petronix model... Nov 29 2011, 03:47 PM
davidj I was looking into this setup:
Boost
:beer2: Nov 29 2011, 11:14 PM
Marty Yeoman I run a MSD 6AL with a Bosch Blue coil, stock Bosc... Nov 30 2011, 02:41 PM
struckn
I run a MSD 6AL with a Bosch Blue coil, stock Bos... Nov 30 2011, 08:33 PM
aharder I'm running a Crane Cams FireBall XR2000, Stoc... Nov 30 2011, 10:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th September 2026 - 03:25 PM |
