> electronic ignition, name the components necessary
OKCSwope
post Nov 25 2011, 09:33 PM
I'm having a hard time sorting through all the possibilities out there. I want to do a pointless ignition. Can you recommend a list of components and prices?
Cap'n Krusty
post Nov 25 2011, 10:06 PM
Cap'n Krusty
QUOTE(OKCSwope @ Nov 25 2011, 07:33 PM) *
Compufire
Crane Allison XR 700
Both are complete kits, both are reliable. The Compufire is readily available, the Crane less so, although Summit may have stock. Anything else is unreliable enough that most knowledgeable techs would warn you to carry a set of points and a condenser, as well as a feeler gauge to set them, in the car.
jaxdream
post Nov 26 2011, 08:03 AM
QUOTE(Cap'n Krusty @ Nov 25 2011, 08:06 PM) *
Compufire
Why not carry an extra set of the electronic ignition that you are using?? Shoudn't be no harder to replace than points & condenser .
I used the first gen. Pertronix in a T1 for years , no problems.
Jack
OKCSwope   electronic ignition   Nov 25 2011, 09:33 PM
rnellums   I used Pertronix on one of mine. Uses a hall sens...   Nov 25 2011, 09:49 PM
OKCSwope   I used Pertronix on one of mine. Uses a hall sen...   Nov 26 2011, 12:04 AM
kg6dxn   I used Pertronix on one of mine. Uses a hall se...   Nov 26 2011, 12:17 AM
hydroliftin   I'm having a hard time sorting through all th...   Nov 25 2011, 09:54 PM
OKCSwope   I'm running a 2.2 dual webers 4 cyl and my goa...   Nov 25 2011, 10:25 PM
Mark Henry   Sounds like Petronics and compu-fire are the best...   Nov 26 2011, 08:43 AM
bigkensteele   I just installed a Pertronix a few weeks ago, and ...   Nov 25 2011, 09:55 PM
Cap'n Krusty   I'm having a hard time sorting through all th...   Nov 25 2011, 10:06 PM
jaxdream   I'm having a hard time sorting through all t...   Nov 26 2011, 08:03 AM
underthetire   Compu fire. Cleaner signal at lower rpm IMO. Both...   Nov 25 2011, 10:51 PM
Socalandy   I want to see more pics of the car in your avitar....   Nov 26 2011, 12:25 AM
rnellums   I believe I got the II, there was no rev limit adj...   Nov 26 2011, 12:34 AM
Spoke   I used this Pertronix module from Pelican. These a...   Nov 26 2011, 06:21 AM
76-914   IIRC, there is curreently only one Petronix model ...   Nov 26 2011, 09:39 AM
struckn   IIRC, there is curreently only one Petronix model...   Nov 29 2011, 03:47 PM
davidj   I was looking into this setup: Boost :beer2:   Nov 29 2011, 11:14 PM
Marty Yeoman   I run a MSD 6AL with a Bosch Blue coil, stock Bosc...   Nov 30 2011, 02:41 PM
struckn   I run a MSD 6AL with a Bosch Blue coil, stock Bos...   Nov 30 2011, 08:33 PM
aharder   I'm running a Crane Cams FireBall XR2000, Stoc...   Nov 30 2011, 10:33 PM
- Lo-Fi Version Time is now: 17th September 2026 - 03:26 PM
