| EdwardBlume |
Nov 25 2011, 06:22 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
I broke the seal from the crank and it broke everything loose except the dowel underneath the oil cooler on the lower side of the engine.
How do I pull this area apart? |
| Jake Raby |
Nov 26 2011, 03:04 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
After watching the video I'll say that you just need to get more aggressive.. I believe the case dowel does have it caught at that area... Use a pair of screwdrivers VERY CAREFULLY on both sides of the area that won't separate and try to spread it open with them both simultaneously.
OR use the screwdriver to load the area up and then carefully chatter against the dowel area with an air hammer and it will probably split right away... A dead blow or rubber mallet probably isn't going to do it, not enough concentrated shock load at the dowel area from those wimpy devices.. Use common sense, but grow a pair because thats the only thing thats going to get it apart. Splitting a case is easy, I have had this happen to me on a couple of occasions but generally they fall apart and they should. Clean that dowel and it's bore really well before reassembly. |
RobW Splitting the Case Nov 25 2011, 06:22 PM
Vacca Rabite Find the bolt you missed.
Zach Nov 25 2011, 06:48 PM
RobW Didn't miss any.... unless there's one ins... Nov 25 2011, 07:06 PM
RobW Here's a bloody pict.... Nov 25 2011, 07:16 PM
RobW Everything is free except the 90 deg underneath th... Nov 25 2011, 07:18 PM
bigkensteele Isn't there one around the oil filler console ... Nov 25 2011, 07:29 PM
RobW
Isn't there one around the oil filler console... Nov 25 2011, 07:35 PM
Van Probably dealing with some corrosion on a dowel pi... Nov 25 2011, 07:58 PM
a914dude Count yer nutz. <_< Nov 25 2011, 08:06 PM
RobW
Count yer nutz. <_<
"testes.. one,... Nov 25 2011, 08:20 PM
RobW LwIMsriGCd4 Nov 25 2011, 08:33 PM
Randal
LwIMsriGCd4
Nice video Rob. You just need to ... Nov 26 2011, 10:55 AM
Mark Henry Is there still a couple of washers on the studs? T... Nov 26 2011, 08:46 AM
jsconst It could be sealant holding it together there, I h... Nov 26 2011, 09:18 AM
RobW Got it.
I carefully took a straight edge piece o... Nov 26 2011, 09:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 06:08 PM |
