| reharvey |
Nov 28 2011, 01:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
Going to glue the vinyl trim to the top of the roll bar only. Not planning to use the trim on the sail panels. I did one of these years ago using 3M heavy duty spray adhesive and it didn't work so well. What have you used? Ray
Attached thumbnail(s) |
| TheCabinetmaker |
Nov 29 2011, 07:57 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,367 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I've been building cabinets and plastic laminate countertops for 40 years. I use a spray can contact cement that I get from my Formica or Wilson Art wholesaler for on site touchup or a spot repair/reglue. In a pinch, I will use the 3m adhesive. Its almost as good as my sprayable contact cement.
Always spray both surfaces, and let dry till it does not transfer to your finger when you touch it. If it sticks to your finger, its not ready and it won't hold. A double coat around the edges (very light second coat) is a good idea too. If you brush it, you must do it evenly without any globs or lumps. The vinyl will show every imperfection underneath it. The cardinal rule here is " cleanliness is next to godliness". One speck of debris will ruin the job. Btw, there is a difference between the sprayable contact cement and the old Weldwood "gorilla snot" in the can. You do not want to put that brushable contact in your spray gun, unless you just want to buy a new gun anyway. One more thing. Don't use the waterborne adhesive. It won't stick! |
| Phoenix-MN |
Nov 29 2011, 10:04 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
Btw, there is a difference between the sprayable contact cement and the old Weldwood "gorilla snot" in the can. You do not want to put that brushable contact in your spray gun, unless you just want to buy a new gun anyway. This is the Spray grade stuff, use lots of solvent and a cheap gun ![]() |
reharvey Best adhesive for roll bar vinyl trim Nov 28 2011, 01:18 PM
Phoenix-MN Hands down this is the best stuff I've ever us... Nov 28 2011, 02:07 PM
andys
Hands down this is the beast stuff I've ever ... Nov 28 2011, 03:05 PM
reharvey
Hands down this is the beast stuff I've ever ... Nov 28 2011, 05:01 PM
Phoenix-MN
[quote name='Phoenix-MN' post='1579955' date... Nov 28 2011, 07:14 PM
Socalandy I went with Worth brand but it didnt hold well aft... Nov 28 2011, 02:28 PM
9146986 3M super trim and vinyl adhesive spray. The impor... Nov 28 2011, 05:24 PM
Jon Fernandes I used 3M Super 77 adhesive. Mask off all the area... Nov 28 2011, 05:34 PM
RiqueMar
I used 3M Super 77 adhesive. Mask off all the are... Nov 28 2011, 07:54 PM
Jon Fernandes
I used 3M Super 77 adhesive. Mask off all the ar... Nov 29 2011, 07:34 AM
scotty b :agree: on the 3M. As Perry said you MUST let the ... Nov 28 2011, 07:23 PM
reharvey
Going to glue the vinyl trim to the top of the ro... Nov 28 2011, 11:10 PM
RobW Use the can as a roller but it will squeegy out ex... Nov 29 2011, 07:50 AM
sean_v8_914 3m super 90 Nov 29 2011, 08:30 AM
andys I used 3M super 77 on some portions of my dash vin... Nov 29 2011, 10:37 AM
reharvey
I used 3M super 77 on some portions of my dash vi... Nov 29 2011, 11:14 AM
vsg914 Weldwood is the original, still the strongest, and... Nov 29 2011, 11:16 AM
reharvey
Weldwood is the original, still the strongest, an... Nov 29 2011, 12:41 PM
76-914 I used the 3m 77 stuff years ago on my airplanes i... Nov 30 2011, 09:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 04:07 PM |
