> Oversize bores, Anyone know the ID's
porschefile2010
post Nov 30 2011, 02:31 AM
Region Association: Australia and New Zealand
Having blown a hole through the head of my 75', so called 2.0 I have now found that the bore has been taken out to 103mm by a PO. If I can I would like to replace the cylinders with smaller bores because I have to do cylinders and therfore pistons anyway because of damage to the cooling vanes.
Question is the size of the outer diameter of the cylinder in the block is 108.3. Does anyone know whether I am likely to get cylinders with a smaller bore that would fit this block. I suspect the 96mm cylinders will be around the 105mm ID in the block?
Ideally the answer would be that the 96mm bore cylinders also have an OD of 108.3 but I won't hold my breath!
Sorry, I guess this is in the wrong Forum
Valy
post Nov 30 2011, 12:51 PM
You might consider keeping the 103mm. The cost of fixing the case and heads back to original will be higher than the new cylinders. See something like this.
http://www.ebay.com/itm/VW-Porsche-Type-4-...7#ht_1374wt_864
If you're fixed on 96mm, I would get a new core engine and work on it. Should be cheaper.
- Lo-Fi Version Time is now: 19th September 2025 - 03:01 PM
