porschefile2010 |
Member ![]() ![]() Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand ![]() |
Having blown a hole through the head of my 75', so called 2.0 I have now found that the bore has been taken out to 103mm by a PO. If I can I would like to replace the cylinders with smaller bores because I have to do cylinders and therfore pistons anyway because of damage to the cooling vanes.
Question is the size of the outer diameter of the cylinder in the block is 108.3. Does anyone know whether I am likely to get cylinders with a smaller bore that would fit this block. I suspect the 96mm cylinders will be around the 105mm ID in the block? Ideally the answer would be that the 96mm bore cylinders also have an OD of 108.3 but I won't hold my breath! Sorry, I guess this is in the wrong Forum |
porschefile2010 |
Thanks Valy. Sounds/looks like the Auto Atlanta kit and maybe from China also. Sounds crazy but I would rather pay more for well proven brands than end up dropping the engine out again because of a piston problem. Has anyone used these cheaper cylinders before. That would be good to know.
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
Thanks Valy. Sounds/looks like the Auto Atlanta kit and maybe from China also. Sounds crazy but I would rather pay more for well proven brands than end up dropping the engine out again because of a piston problem. Has anyone used these cheaper cylinders before. That would be good to know. Most of us use the AA 96mm sets. I'm currently rebuilding an engine with that set. See my signature. |
Lo-Fi Version | Time is now: 19th September 2025 - 03:02 PM |
