porschefile2010 |
Member ![]() ![]() Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand ![]() |
Having blown a hole through the head of my 75', so called 2.0 I have now found that the bore has been taken out to 103mm by a PO. If I can I would like to replace the cylinders with smaller bores because I have to do cylinders and therfore pistons anyway because of damage to the cooling vanes.
Question is the size of the outer diameter of the cylinder in the block is 108.3. Does anyone know whether I am likely to get cylinders with a smaller bore that would fit this block. I suspect the 96mm cylinders will be around the 105mm ID in the block? Ideally the answer would be that the 96mm bore cylinders also have an OD of 108.3 but I won't hold my breath! Sorry, I guess this is in the wrong Forum |
porschefile2010 |
Thanks Rich. Not really that easy. I think there are now seven or eight 914's in thcountry. Lots of VW followers and I have a good Type 4 mechanic looking at it to, but getting parts is thrick. The piston /cylinder sets on Auto Atlanta are in their performance parts section and seemed real cheap but you are probably dead right about their origin which is a bit scary-nfortunately.
I have seent Chris an email so will see what comes back. Thanks again for your interest. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Thanks Rich. Not really that easy. I think there are now seven or eight 914's in thcountry. Lots of VW followers and I have a good Type 4 mechanic looking at it to, but getting parts is thrick. The piston /cylinder sets on Auto Atlanta are in their performance parts section and seemed real cheap but you are probably dead right about their origin which is a bit scary-nfortunately. I have seent Chris an email so will see what comes back. Thanks again for your interest. My point is look into the locals that sell Type1 parts. They most likely sell the pistons and cylinder from the same manufacturer for the type 1 crowd...so that means they can order the type4 ones for you. Rich |
Lo-Fi Version | Time is now: 19th September 2025 - 03:01 PM |
