> electronic ignition, name the components necessary
OKCSwope
post Nov 25 2011, 09:33 PM
I'm having a hard time sorting through all the possibilities out there. I want to do a pointless ignition. Can you recommend a list of components and prices?
MartyYeoman
post Nov 30 2011, 02:41 PM
I run a MSD 6AL with a Bosch Blue coil, stock Bosch dizzy and stock non-rev limiter rotor. MSD plug wire set and a Pertronix points module. All this on a L-jet motor. I've never had a problem with this combination.
struckn
post Nov 30 2011, 08:33 PM
QUOTE(Marty Yeoman @ Nov 30 2011, 12:41 PM) *
That's a good set up but I don't think having a MSD Unit plus a Pertronix's in the Dizzy is a good idea. I noticed a better low RPM transition with the MSD deleted. It might also be that deleting the Pertronixs and keeping the MSD would work better as well. It's also possible that the MSD 5 I have is busted.
OKCSwope   electronic ignition   Nov 25 2011, 09:33 PM
rnellums   I used Pertronix on one of mine. Uses a hall sens...   Nov 25 2011, 09:49 PM
OKCSwope   I used Pertronix on one of mine. Uses a hall sen...   Nov 26 2011, 12:04 AM
kg6dxn   I used Pertronix on one of mine. Uses a hall se...   Nov 26 2011, 12:17 AM
hydroliftin   I'm having a hard time sorting through all th...   Nov 25 2011, 09:54 PM
OKCSwope   I'm running a 2.2 dual webers 4 cyl and my goa...   Nov 25 2011, 10:25 PM
Mark Henry   Sounds like Petronics and compu-fire are the best...   Nov 26 2011, 08:43 AM
bigkensteele   I just installed a Pertronix a few weeks ago, and ...   Nov 25 2011, 09:55 PM
Cap'n Krusty   I'm having a hard time sorting through all th...   Nov 25 2011, 10:06 PM
jaxdream   I'm having a hard time sorting through all t...   Nov 26 2011, 08:03 AM
underthetire   Compu fire. Cleaner signal at lower rpm IMO. Both...   Nov 25 2011, 10:51 PM
Socalandy   I want to see more pics of the car in your avitar....   Nov 26 2011, 12:25 AM
rnellums   I believe I got the II, there was no rev limit adj...   Nov 26 2011, 12:34 AM
Spoke   I used this Pertronix module from Pelican. These a...   Nov 26 2011, 06:21 AM
76-914   IIRC, there is curreently only one Petronix model ...   Nov 26 2011, 09:39 AM
struckn   IIRC, there is curreently only one Petronix model...   Nov 29 2011, 03:47 PM
davidj   I was looking into this setup: Boost :beer2:   Nov 29 2011, 11:14 PM
Marty Yeoman   I run a MSD 6AL with a Bosch Blue coil, stock Bosc...   Nov 30 2011, 02:41 PM
struckn   I run a MSD 6AL with a Bosch Blue coil, stock Bos...   Nov 30 2011, 08:33 PM
aharder   I'm running a Crane Cams FireBall XR2000, Stoc...   Nov 30 2011, 10:33 PM
- Lo-Fi Version Time is now: 17th September 2026 - 03:26 PM
