| Broz97 |
Nov 29 2011, 06:53 PM
Newbie ![]() Group: Members Posts: 13 Joined: 6-August 11 From: Mile High Denver Member No.: 13,407 Region Association: Southwest Region |
Hello 914 World... What a terrific site and help to anything 914. Now here is my dilemma... Need help in Denver, CO
I have been sorting my friends 1973 1.7L FI D-Jet 914 for a couple months now including all fuel and vacuum hoses, hell hole, clean and lube distributor, new points and condenser, fuel injector seals, intake rubbers, all Rennlist checks... et al. Good news.... She runs great when I start her with a remote starter... Bad news is the motor starts really hard and won.t stay running if I use the ignition switch or even attempt to push the yellow wire onto the solenoid when it is idling after a remote switch start. Of course it makes sense that maybe the ignition switch is crap and bleeding off current or...? I have ordered a new switch but... Maybe I missing something here.... Like I said it runs and is so tuneable if I remote start and dead to me if I use the ignition switch as designed. Anyone got any ideas on how to check this out... BTW, I have wrenching on bikes Triumph, BSA and most of the Japanese stuff nad a few VW bugs since the 60's and find the 914 pretty wrench friendly... |
| 76-914 |
Nov 30 2011, 09:44 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,962 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Who needs trigger points, just wire them all in hot. Perhaps this was the predecessor of CIS?
| majkos |
Nov 30 2011, 09:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
Who needs trigger points, just wire them all in hot. Perhaps this was the predecessor of CIS? You think!? correct me if I'm wrong. 009 dist. is for carbs. and maybe 1.8 L injection? forgive my humble yet forgetful mind as I'm up my ass in house repair and need to escape! Broz where are you at ? |
| underthetire |
Nov 30 2011, 10:10 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Who needs trigger points, just wire them all in hot. Perhaps this was the predecessor of CIS? You think!? correct me if I'm wrong. 009 dist. is for carbs. and maybe 1.8 L injection? forgive my humble yet forgetful mind as I'm up my ass in house repair and need to escape! Broz where are you at ? I thought the 009 was to keep the newspaper from flying out of the garbage can.). He did say 73 1.7, we all would assume djet then... |
Broz97 Ignition Starter wire to solenoid kills engine Nov 29 2011, 06:53 PM
brant I don't know the answer
doesn't sound like... Nov 29 2011, 07:02 PM
Broz97
doesn't sound lik... Nov 30 2011, 10:00 AM
r_towle look under the passenger seat.
If you see what loo... Nov 30 2011, 10:29 AM
majkos :popcorn: Progress ?
I'm in Lakewood, so sor... Nov 30 2011, 11:17 AM
Broz97
I'm in Lakewood, so so... Nov 30 2011, 12:34 PM
r_towle not sure if you have it...its a 73/74 thing...one ... Nov 30 2011, 12:45 PM
Broz97
not sure if you have it...its a 73/74 thing...one... Nov 30 2011, 01:36 PM
Broz97
[quote name='r_towle' post='1581041' date='Nov 30... Nov 30 2011, 02:19 PM
rnellums
not sure if you have it...its a 73/74 thing...one... Nov 30 2011, 07:06 PM
Broz97
not sure if you have it...its a 73/74 thing...on... Nov 30 2011, 07:22 PM
vsg914 Thats just the connection to make the fasten seat ... Nov 30 2011, 02:58 PM
Broz97
Thats just the connection to make the fasten seat... Nov 30 2011, 03:16 PM
Broz97
Thats just the connection to make the fasten sea... Nov 30 2011, 03:20 PM
vsg914 White wire on the coil? Where does it go? What oth... Nov 30 2011, 04:33 PM
underthetire Er, green should be on the -. That should be from ... Nov 30 2011, 07:51 PM
Broz97
Er, green should be on the -. That should be from... Nov 30 2011, 08:07 PM
majkos No, the problem is car is running but the wires is... Nov 30 2011, 08:20 PM
76-914 Now I'm confused about the logic board. I have... Nov 30 2011, 08:38 PM
majkos :toke:
weird, huh? Nov 30 2011, 08:41 PM
Broz97
:toke:
weird, huh?
Thanks guys for adding som... Dec 1 2011, 12:38 PM
underthetire Move the green wire and try to figure out where th... Nov 30 2011, 09:40 PM
majkos
[quote name='majkos' post='1581287' date='Nov 30 ... Nov 30 2011, 10:13 PM
rick 918-S
If you click on the picture you will get a c... Nov 30 2011, 09:50 PM
majkos Dam Rick!
You're good :first: Nov 30 2011, 09:56 PM
phatnine11 never mind, brain fart!
Cesar Nov 30 2011, 10:03 PM
jcd914 At the coil there should be a black and red wire g... Dec 1 2011, 12:58 AM
cwpeden How does the relay board look? Bad Starter realy ... Dec 1 2011, 01:33 AM
vsg914 Move the green wire to the- side of the coil. Remo... Dec 1 2011, 05:40 AM
Tom Broz97,
Someone has done some rewiring. Here i... Dec 1 2011, 09:11 AM
majkos So the remote starter is clipped to the starter it... Dec 1 2011, 01:52 PM
SLITS Starter wire.....
Comes from ignition switch to P... Dec 1 2011, 04:54 PM
majkos That make sense.
Now Broz, get out there and chec... Dec 1 2011, 05:14 PM
SLITS And I should have added that the white wire that g... Dec 1 2011, 06:12 PM
Broz97
And I should have added that the white wire that ... Dec 1 2011, 10:40 PM
jcd914
And I should have added that the white wire that... Dec 1 2011, 11:13 PM
Broz97
[quote name='Broz97' post='1581815' date='Dec 1 2... Dec 10 2011, 02:40 PM
vsg914 There is one more white wire in that area, but onl... Dec 10 2011, 03:46 PM
Broz97
There is one more white wire in that area, but on... Dec 16 2011, 08:55 AM
vsg914 If you would have listened to us to begin, with yo... Dec 16 2011, 09:31 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th September 2026 - 03:22 PM |
