Piston/Cylinders, Are they built well? |
davidj |
Nov 29 2011, 10:49 PM
Newbie Group: Members Posts: 41 Joined: 19-November 08 From: Ventura, Ca Member No.: 9,771 Region Association: Southern California |
I was lurking around today for some piston/Cylinder kits and came across these and wanted to know if they were good for a "Street Performance" engine. I do know that these are less expensive then the Nickeys. But still could be a good product.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.europeanmotorworks.com-9771-1322628561.1.jpg) 103mm Aluminum Alloy, NiCaSil-coated cylinder From European Motorworks $735.00 And then came across these from AA. And was wondering if these are better then the stock cast iron type? (IMG:http://www.914world.com/bbs2/uploads_offsite/c767170.r70.cf2.rackcdn.com-9771-1322628561.2.jpg) 96MM ALUMINUM BIRAL CAST IRON PISTON/CYLINDER KIT $385.95 If anyone has any experience with these I would apreciate it to hear from you. Thanx, Dave |
McMark |
Dec 1 2011, 09:35 PM
Have you read this article? LN Engineering. The third section talks about Birals. Good info.
davidj |
Dec 2 2011, 01:55 PM
Thanks for the info. Clearly a biased rant for thier product, but they do admit that: "biral-type aluminum finned iron-lined cylinders do typically cool better than cast iron cylinders" So I may try those if the Aluminum cylinders dont work out. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 02:02 AM |
