stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I have a "Mid America" Performance Choice Short Shift Kit 911/914 65-72.
Part # 406117A (like that helps) It has the shorter shifter with longer lower lever. It also has the aluminum spacer to put under the stock shifter. This would be for a stock tail shifter. Anybody tried one of these? Stu |
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
One way to see if you like it is to grab the shift rod between the shift boot and the knob and try shifting.
Because you are closer to the pivot point of the shaft, the throw is less. The problem is people use them to speed shift. Wanna play beat the syncro's? Long shifter gives more time for the shift which gives more time for the synchros to syncronize the speed between the tranny shafts. It's quicker shifting with a short shifter, but the carnage in the tranny is ugly.. (IMG:style_emoticons/default/barf.gif) (IMG:style_emoticons/default/barf.gif) (IMG:style_emoticons/default/barf.gif) And yes, I speed shift from time to time. Was called out driving to lunch by a guy that owns a factory Porsche Turbo. (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/biggrin.gif) I try to take it easier now. |
Lo-Fi Version | Time is now: 6th July 2025 - 10:06 AM |
