New to forum. Hi!, Bought 74 1.8... Stuck in gear! |
silverbullet75 |
Dec 4 2011, 01:05 AM
I reject your reality and substitute my own! Group: Members Posts: 18 Joined: 3-December 11 From: Las Vegas, NV Member No.: 13,848 Region Association: Southwest Region |
Hi all! My name is Jim.
I just bought a 74 1.8 I am in process of getting it titled (hasn't been titled since '04). Once that's finished, the first order of business for the car is to fix the transmission issue. It's not a linkage problem, because I can manually shift the side-shifter from under the car, but it just won't get out of gear. Had to disconnect an axle to get it off the trailer. Interesting thing though... the (interior) shifter will feel like it's going into gears and neutral, but it's not really. Hoping someone has run into this issue before and knows what it is without me having to even pull the tranny. |
silverbullet75 |
Dec 4 2011, 09:20 PM
Here you go!
... and added my VIN too. (IMG:style_emoticons/default/smile.gif) http://ppl.ug/KlcJOxLwlTE/ http://ppl.ug/hkceFEImAmA/ http://ppl.ug/kgFnBCYoWWo/ http://ppl.ug/uKMOJ8e2Ji0/ http://ppl.ug/XtPbGCDq3HA/ It's in rough shape, but very little rust. At least no "cancer" rust... The tranny is the main concern right now. It should go into neutral manually from underneath, regardless of clutch position... but does not. The shaft moves properly at the side-shifter, but just doesn't release to neutral internally. This is my 4th 914, but I've never had transmission trouble on any of the previous ones... so I'm kinda in the dark at this point. But as I stated earlier, I'm not going to pull it apart until I know I own it... fully titled. |
Lo-Fi Version | Time is now: 1st June 2024 - 09:35 AM |
