New to forum. Hi!, Bought 74 1.8... Stuck in gear! |
silverbullet75 |
Dec 4 2011, 01:05 AM
I reject your reality and substitute my own! Group: Members Posts: 18 Joined: 3-December 11 From: Las Vegas, NV Member No.: 13,848 Region Association: Southwest Region |
Hi all! My name is Jim.
I just bought a 74 1.8 I am in process of getting it titled (hasn't been titled since '04). Once that's finished, the first order of business for the car is to fix the transmission issue. It's not a linkage problem, because I can manually shift the side-shifter from under the car, but it just won't get out of gear. Had to disconnect an axle to get it off the trailer. Interesting thing though... the (interior) shifter will feel like it's going into gears and neutral, but it's not really. Hoping someone has run into this issue before and knows what it is without me having to even pull the tranny. |
rick 918-S |
Dec 5 2011, 08:48 AM
Hey nice rack! -Celette Group: Members Posts: 20,489 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
What is the paint code? (IMG:style_emoticons/default/idea.gif) I'm sure if this is your 4th 914 you know where to look but just incase, drivers side between the hinges on the A pillar.
silverbullet75 |
Dec 5 2011, 10:37 AM
What is the paint code? (IMG:style_emoticons/default/idea.gif) I'm sure if this is your 4th 914 you know where to look but just incase, drivers side between the hinges on the A pillar. Ahhh... I see why you ask. I said the car was an "SE". From what I remember, maybe I got the term wrong, an SE just meant it has all the "cool" options like front/rear sway bars, center consoles, etc... Is there another term you use for this option package? My apologies/mistake. (IMG:style_emoticons/default/bye1.gif) I crossed it out on my original post. I think you thought I was claiming it is an LE... no it is not. L3OE is the code. Bahia Red. Also, I hope my "4th 914" comment didn't seem cocky... not my intent. I had those cars from 1991 to 1995. Note: I was in High School until '93. 2 of which were worse than my current one (Hawaii rust). The 3rd one was my pride 'n joy. It was a 74 1.8, with big bore 96mm, all done correctly. GT flares, 916 nose, etc, etc... I'll try to scan some pics later (pics taken before digital cameras existed... LOL). (IMG:style_emoticons/default/welcome.png) As Mike said above it could be a few different things internally. But, if you provide some more info, we could try to debug it more before you open it up. With the side shifter, when in neutral, you should be able to move the shift rod on the side shift console in/out. Are you able to do this? If not, what motion works/doesn't work? Richard Thanks Richard. Yes, I am able to move the shift rod in/out. |
Lo-Fi Version | Time is now: 7th June 2024 - 09:09 AM |
