| Jon Kincaid |
Dec 4 2011, 09:31 PM
Newbie ![]() Group: Members Posts: 3 Joined: 1-November 11 From: Glendora, ca Member No.: 13,729 Region Association: Southern California |
I have dual Dellorto carbs on my 2.0 and I've had them tuned a few times by a shop by my house but I feel like it still doesn't have very great throttle response. Also, the carbs cough above 3,000 rpm and I'm getting popping out of the exhaust under deceleration. Any advice about what is going on with my carbs and any recommendations of shops in SoCal that do quality work on type 4s would be awesome!
Thanks in advance, Jon |
| SUNAB914 |
Dec 5 2011, 12:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
Jon, I just recently put duel dells on my 75 2.0 and they run great. I had expected more fine tuning, but they didn't require alot, maybe because of the duel webber experience on my 74. Who knows and cares. Anyway, first thing i did was rebuild them myself, not hard at all. I called these guys, told them what I had and ordered new jets, and everything just came out real good.
http://www.aircooledengineering.com/services.htm Secondly, you must make sure your timing is correct or you will just chase your tail trouble shooting. next make sure linkage between the two is correct and even. very important! Next syncro them. Then you should be very close and require only a few adjustments. Popping probably means they are lean unless you have an exhaust leak. Good luck you can PM me if you need further help. Hope this helps. I have a list of the jet sizes I used at home if you need them. |
Jon Kincaid Any quality shops in SoCal? Dec 4 2011, 09:31 PM
Steve :wttc:
Otto's in Venice is awesome with 914... Dec 4 2011, 09:39 PM
Socalandy My long time friend and engine builder, Craig at I... Dec 4 2011, 10:03 PM
klink You might give Scotty a call at Steve's Machin... Dec 5 2011, 12:13 AM
76-914
You might give Scotty a call at Steve's Machi... Dec 5 2011, 08:36 AM
monkeyboy
You might give Scotty a call at Steve's Machi... Dec 5 2011, 11:07 AM
thelogo
You might give Scotty a call at Steve's Machi... Dec 5 2011, 12:14 PM
oldschool
You might give Scotty a call at Steve's Machi... Dec 5 2011, 08:09 PM
monkeyboy
You might give Scotty a call at Steve's Mach... Dec 7 2011, 12:00 AM
oldschool
[quote name='oldschool' post='1583950' date='Dec ... Dec 7 2011, 12:35 AM
Tom_T Any of the above, plus Der Buggy in Garden Grove d... Dec 5 2011, 12:48 AM
Jake Raby Dave Greiner at Proformance in Orange is my SoCal ... Dec 5 2011, 07:29 AM
mharmon Callas Rennsport in Torrance does a real good job Dec 5 2011, 11:36 AM
Jon Kincaid Thanks guys for all your recommendations! I... Dec 5 2011, 06:24 PM
yeahmag Let's start simple first. What jetting do you ... Dec 6 2011, 03:50 PM
vwsamba IMHO and experience, if you are going to keep the ... Dec 8 2011, 01:27 AM
monkeyboy I didn't realize you are in Glendora... I... Dec 8 2011, 08:53 AM
Jon Kincaid I think you guys are right in saying that it is le... Dec 8 2011, 09:06 PM
DonTraver Quick question. Nobody asked and I hate to assume... Dec 9 2011, 01:47 PM
monkeyboy I have extra jets laying around after jetting mine... Dec 10 2011, 10:56 AM
klink I just wanted to follow up on this a little. I su... Dec 10 2011, 11:36 PM
mrbubblehead hi jon, i live in yucaipa and could give you a han... Dec 11 2011, 12:42 AM![]() ![]() |
Lo-Fi Version | Time is now: 22nd September 2026 - 12:45 AM |
