| TC 914-8 |
Dec 8 2011, 09:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 840 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest
I just found out my wifes coworker, The Dr Vet's husband, has a 75 2.0 with a dual Weber downdraft conversion. I stopped by last weekend to take a look. it has some minor electrical issues which I should be able to sort out fairly quick with proper diagnostics. Horn, lights etc..
One of his main concerns is mis firing and sputtering during acceleration. It is a fairly clean set up bought from a guy in Bremerton back in 2000. I forgot his name but should be active on this site. so under slight acceleration, reving the engine it sputters around 2500 RPM. with no gauges or tools I noticed the F/A screws on the driverside carb were out different ratios. I gave them a slight adjustment and it seemed to help. I figure we need a air flow meter to put over each venturi and dial in each barrel evenly. (IMG:style_emoticons/default/idea.gif) Being a V-8 guy I would slap on a vaccume gauge and adj from there.... I did not see any vacume ports so its all new to me (IMG:style_emoticons/default/confused24.gif) How do you boys dial these babys in? I was also under the impression a stock FI cam is not really compatible running carbs... (IMG:style_emoticons/default/confused24.gif) Shoot me some ideas , once I get him running, I will have a new teener buddy in the neighborhood to tool around with since you Teener Tuesday boys are afraid of coming accross on the ferry (IMG:style_emoticons/default/poke.gif) |
| jaxdream |
Dec 9 2011, 08:42 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Don't forget to adjust the valves before syncing and ignition checkout. Talk him into an electronic points replacement while your at it. Also check the advance mechanism in the distributor, make sure it advances and retards as it should. Good luck .....
Jack |
TC 914-8 Tuning dual Webers Dec 8 2011, 09:53 PM
Ductech I would start with thinking about how long this ca... Dec 8 2011, 10:06 PM
TC 914-8
I would start with thinking about how long this c... Dec 8 2011, 11:52 PM
Ductech Some people used old sync gauges that would go ove... Dec 8 2011, 11:59 PM
nathansnathan
Some people used old sync gauges that would go ov... Dec 9 2011, 09:40 AM
mrbubblehead i use a snail for synchronizing and an innovate ai... Dec 9 2011, 12:07 AM
rdauenhauer and there is the old standby...ditch the carbs ... Dec 9 2011, 09:51 AM
stownsen914 Cars that haven't been run much can obviously ... Dec 9 2011, 11:22 AM
stownsen914 Oops duplicate post Dec 9 2011, 11:25 AM
messix Have I not taught you any thing?
Go give it an I... Dec 9 2011, 11:36 AM
J P Stein There are a number of things that could be causing... Dec 9 2011, 11:50 AM
pt_700 slightly ot but, i had an old mechanic friend once... Dec 9 2011, 12:48 PM
TC 914-8 Wow, thanks guys for all the input, I like the Car... Dec 9 2011, 09:09 PM
a914622 Hey i have a snail syncer i could let you use to s... Dec 9 2011, 10:36 PM
mrbubblehead
Just a thought but i rigged a vacuum line back o... Dec 9 2011, 10:55 PM
TC 914-8
Hey i have a snail syncer i could let you use to ... Dec 10 2011, 01:05 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 08:13 AM |
